Home > Maintenance & Modifications > ebc yellowstuff over brembo
jack.bauer
seen recommendation on this forum for EBC yellowstuff as an 'upgrade' from oem.
looking into it, found a 20page long thread over at pistonheads with horror stories.
http://www.pistonheads.com/gassing/topic.a...&mid=0
from what ive gathered there, the horror stories seem to be down to
1) drivers using the wrong coloured pads for their designated cars (e.g. greenstuff when their car should have something else)
2) drivers ripping it around tracks
3) early compound which have since been replaced by newer stuff
first two dont apply to me in a RRS doing town driving. does anyone here have any experience with these?
or just stick with the oem brembo (which i understand are the ferodo ones) 07 TDV8 + BAS map
Post #441028 Fri Oct 31 2014 11:47am
chilly
United Kingdom 2006 Range Rover Sport Supercharged HST Java Black
I've used ebb stuff on my cars for years i can't fault them not had any break fade or anything since using them and i do have a fast aggressive driving style
only problems I've seen is people using wrong pads for there cars weight etc or using track pads on the road dues to the track pads need so good warming up before they become effective so you get people putting them on there corsas pulling out of drive and then going straight through a red light due to not been able to stop as pads art warm and have very little braking force
but you'd have no problems using brembo pads either or mintex
you can go on ebb website and it tells you what ones you'd need and gives you differences between each pad only the dead truely know peace,
Bootneck its not a job its a way of life!
Post #441029 Fri Oct 31 2014 12:12pm
jack.bauer
Thanks chilly. Think I'll stick to brembos, not feeling adventurous.
I have found that there are two variations
Standard discs and drilled+grooved . anyone got experienced with these drilled+grooved ? 07 TDV8 + BAS map
Post #441059 Fri Oct 31 2014 8:17pm
Disco_Mikey
I have Redstuff with drilled and grooved discs.
Pads are OK when cold, but a bit wooden. Get better the hotter they get, and are a low dust pad
Discs warped after 3k miles...
Post #441073 Fri Oct 31 2014 10:13pm
jack.bauer
Yikes
Disc warped due to pads or due to the funky grooves thing?
And are these brembo discs or ebc? 07 TDV8 + BAS map
Post #441082 Fri Oct 31 2014 11:08pm
Disco_Mikey
Discs are made by Terrfirma, sold by Allmakes. Were not particularly cheap either...
And they are a bit noisy when braking, a characteristic dpor drivelled and grooved discs
Stick to normal discs, IMHO. D+G discs are not worth the extra cost.
Post #441099 Sat Nov 01 2014 8:13am
Camelrock
I got Brembo discs and pads, got brake judder after 3k miles, got the discs changed under warranty another 3k miles same again though haven't tried for another claim yet. I don't really want to have to change the brakes every 3k so are there any other brands out there which will perform any better ?? 2008 G4 RRSport TDV8 current
2009 TDCi 90 current
1994 Dakar current
Post #441101 Sat Nov 01 2014 8:47am
Disco
You can get updated Brembo Discs with grooves or drilled. The pads we get with the std Brembo calliper are probably Land Rover not Brembo.
The updates include the Discs, pads and hoses.
Have a look at the Brembo website.
Post #441159 Sat Nov 01 2014 8:57pm
jack.bauer
currently looking at standard brembo discs & pads http://www.ebay.co.uk/itm/RANGE-ROVER-SPOR...4d1d6a4cef
vs grooved & drilled brembo discs with standard brembo pads http://www.ebay.co.uk/itm/RANGE-ROVER-SPOR...4ad571896e
or brembo discs with ferodo premier pads http://www.amazon.co.uk/Ferodo-FDB1996-Bra...ds=FDB1996
or there is a painted version of the standard brembo discs on their website http://www.amazon.co.uk/Brembo-09-8877-31-...elId=23051 (by painted im guessing it's the UV stuff to prevent corrosion ?) 07 TDV8 + BAS map
Post #441175 Sun Nov 02 2014 2:32am
