| RRSPORT.CO.UK | ||
|  | Home > General > Vibration at 20mph and breaking |
| Paddi Member Since: 06 Jul 2012 Location: Hertfordshire Posts: 1563      | Hi, the only thing that I have had that coincided with all those symptoms was a failing front differential. It is a known problem with vehicles of around that manufacturing year. Approximately a thousand pounds for the part from LR. Check to see if the vibration occurs when you lift off from high speed but without braking - seems to be a good indication of the diff failing.
|  Sun Oct 26 2014 2:36pm |
| zacattack1845 Member Since: 03 Aug 2014 Location: Essex Posts: 25      | Thanks for the response. Wheels were recently balanced & not been off roaring but just before I bought the vechile (6 weeks back) the brakes (disks & pads) were in fact changed. They were really squeaky but that seems to have gone now.
|  Sun Oct 26 2014 3:00pm |
| Paddi Member Since: 06 Jul 2012 Location: Hertfordshire Posts: 1563      | New brakes if fitted correctly and good quality parts should not squeal. If the discs had excess run out would be OK for about 1k miles then start vibrating when applied.
|  Sun Oct 26 2014 4:20pm |
| zacattack1845 Member Since: 03 Aug 2014 Location: Essex Posts: 25      | Would brakes vibrate all the time or just on breaking? Might be a silly question   | ||
|  Sun Oct 26 2014 4:29pm |
| Paddi Member Since: 06 Jul 2012 Location: Hertfordshire Posts: 1563      | There are no silly questions only silly answers  | ||
|  Sun Oct 26 2014 5:59pm |
| simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657      | Brakes won't cause a vibration at one speed, more likely a heat shield or as already mentioned if you have a whine, diff or wheel bearing. To check diff oil, drain in to a clean container then filter into another container with Mrs best flour strainer. If there is any metal partiicals or black bits of paint then diff is goosed. If you have a transmission specialists such as TES near you, they usually have a rolling road and can pinpoint source of noise while running the system. Our Disco did something similar and turned out to be rear diff even though noise sounded like front. Quick check with stethoscope revealed and worn front wheel bearing too.   | ||
|  Sun Oct 26 2014 6:02pm |
| zacattack1845 Member Since: 03 Aug 2014 Location: Essex Posts: 25      | Thanks for you reply  | ||
|  Sun Oct 26 2014 6:03pm |
| zacattack1845 Member Since: 03 Aug 2014 Location: Essex Posts: 25      | Would the diff issue be related to the brakes of will they be separate issues? | ||
|  Sun Oct 26 2014 6:05pm |
| simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657      | Completely seperate issues and with different symptoms. 2x TDV6. SE and HSE. Both returned to sender with issues👀
|  Sun Oct 26 2014 8:05pm |
| Posting Rules
