Home > Maintenance & Modifications > Headlamp washers not working
Bob
2006 Range Rover Sport Supercharged Zermatt Silver
Hope there's a quick answer to this (but I can't find it).
I noticed that my headlight washers don't work. Not sure how long that's been going on for (it might be a year or so, I can't remember).
The front and rear washers work perfectly, and I know all about the 1 wash every 5 squirts of the windscreen etc., and that you need to have your headlights on, but I get not a trickle!
I've looked at the fuses, and there doesn't appear to be a dedicated one for the headlamp washers (apart from something with a little loop inside a tiny relay case, next to the fuses under the bonnet).
Does the headlamp water have it's own dedicated pump (in which case, it may have seized, fairly common, in my experience), and does it have a dedicated fuse that I haven't spotted.
Anyone else have any problems with headlamp washers?
Thanks.
Bob.
Post #325367 Fri Dec 16 2011 6:47pm
Bob
O.k., I'll answer this one myself.
The pump was rusted solid. I replaced it, and everything worked o.k.
Bob.
Post #438644 Mon Oct 06 2014 12:52pm
gogsy1956
Bob
where exactly is this pump located Question 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #438658 Mon Oct 06 2014 6:26pm
Bob
It's attached to the washer bottle, which is behind the front bumper, under the nearside (UK) wheel-arch.
Bob.
Post #438662 Mon Oct 06 2014 6:34pm
gogsy1956
cheers Thumbs Up 2010 RRS, TDV8
22" overfinch
Post #438681 Mon Oct 06 2014 9:26pm
