Bob
Headlamp washers not working | |
Hope there's a quick answer to this (but I can't find it).
I noticed that my headlight washers don't work. Not sure how long that's been going on for (it might be a year or so, I can't remember).
The front and rear washers work perfectly, and I know all about the 1 wash every 5 squirts of the windscreen etc., and that you need to have your headlights on, but I get not a trickle!
I've looked at the fuses, and there doesn't appear to be a dedicated one for the headlamp washers (apart from something with a little loop inside a tiny relay case, next to the fuses under the bonnet).
Does the headlamp water have it's own dedicated pump (in which case, it may have seized, fairly common, in my experience), and does it have a dedicated fuse that I haven't spotted.
Anyone else have any problems with headlamp washers?
Thanks.
Bob.
Fri Dec 16 2011 7:47pm |
