Home > Maintenance & Modifications > Front wishbones/bushes question
saty
United Kingdom 2005 Range Rover Sport TDV6 HSE Zermatt Silver
Hi all,
I need to replace my "front wishbone, rear bush" ... Can someone please advise if these can be purchased singly or are they a complete unit "whole arm"?
Cheers, Saty
Post #437500 Tue Sep 23 2014 3:55pm
Bodsy
Site Sponsor
You can replace just the bush, but invariably, the bolts need cutting out. And once repaired, the other bush or ballpoint will be failing soon.
The whole front lower arm is about £120 istr which includes both bushes and ball joint.
You will need new bolts and make sure you copperslip them to make it easier for next time! Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #437518 Tue Sep 23 2014 6:15pm
Disco_Mikey
If you are paying someone else to do the job, is works out cheaper to cut the arm off, and replace the whole thing as a complete unit. The bolts are a hardened steel, and can take a long time to cut through. And then the time to replace the bushes
At least with replacing complete arms, it comes with 2 new bushes, and a new ball joint on each side Thumbs Up
Wishbones can be had for £100 per side, for a known good brand, and another £20 or so for a new set of bolts and adjusting washers Thumbs Up
Post #437530 Tue Sep 23 2014 7:42pm
saty
Thanks chaps for the replies.
Can you let me know when these can be purchased from, links would be great?
Post #437576 Wed Sep 24 2014 8:03am
Bodsy
Site Sponsor
Full kit here...
http://www.advancedfactors.co.uk/003rrs-fr...5647-p.asp
Dan @ Duckworths LR can also be competitive Thumbs Up Bodsys Brake Bible
See it HERE
Post #437586 Wed Sep 24 2014 10:05am
saty
Bodsy... Great THANKS Bow down
Post #437587 Wed Sep 24 2014 10:22am
