![]() | Home > Maintenance & Modifications > Front wishbones/bushes question |
You can replace just the bush, but invariably, the bolts need cutting out. And once repaired, the other bush or ballpoint will be failing soon.
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4521 ![]() ![]() ![]() |
If you are paying someone else to do the job, is works out cheaper to cut the arm off, and replace the whole thing as a complete unit. The bolts are a hardened steel, and can take a long time to cut through. And then the time to replace the bushes
saty Member Since: 17 Aug 2011 Location: Beds Posts: 227 ![]() ![]() ![]() |
Thanks chaps for the replies.
Full kit here...
Bodsy... Great THANKS |
