Home > Technical > EPb squeal
W18ODY
EPb squeal
So my park brake is making the familiar squealing noise, im going to take a look at it and im presuming it needs adjusting.
reading the guides it says if im just adjusting it and not removing the disc i dont need to put it in service mode but if im removing the disc and doing further work i should, obviously i have no way of doing this.
i am only planning on adjusting it at the moment but i was wanting to remove the disc to see how much material is on the shoes as it may be that they need replacing.
So basically my question is do i really need to put it in service mode? whats this job like? as it looks like everything will be seized up but the guides as always make it look so straight forward haha
Thanks in advance
Post #437331 Sun Sep 21 2014 5:40pm
Bodsy
Site Sponsor
Have you tried the brake bible....? It should give you all the steps you need. I would take the disk off to copper slip all the friction points and then adjust it. Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #437333 Sun Sep 21 2014 6:17pm
W18ODY
yes mate great piece of information hats off to you Thumbs Up
whats the adjuster like for seizing up?
also as a daft as this may sound when it refers to adjustment in "clicks" is a single click one notch on the adjuster wheel?
Post #437334 Sun Sep 21 2014 6:22pm
