| RRSPORT.CO.UK | ||
|  | Home > Faults & Fixes > Suspension goes into 'Extended mode' |
| Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4532      | More than likely a blocked air dryer, or a blocked exhaust valve   | ||
|  Mon Sep 15 2014 11:30am |
| leedantex Member Since: 15 Sep 2014 Location: Manchester Posts: 7      | Thanks for the reply.
|  Mon Sep 15 2014 11:44am |
| Bodsy Site Sponsor Member Since: 03 Feb 2007 Location: Shropshire Posts: 2162    | Maybe also a ride height sensor.
|  Mon Sep 15 2014 11:53am |
| Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4532      | The dryer can be emptied of its contents (silica gel and filters), and put together to test
|  Mon Sep 15 2014 11:55am |
| leedantex Member Since: 15 Sep 2014 Location: Manchester Posts: 7      | Thanks Bodsy, I tried this yesterday and it SEEMS to be fine when on the 4x4 screen. The front 2 wheels lower at the same rate to access height then the back ones do not even try, they simply stay on normal mode height and the message pops up. There is no flashing or juddering on the 4x4 screen.
|  Mon Sep 15 2014 12:25pm |
| Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4532      | Yes to both counts   | ||
|  Mon Sep 15 2014 12:58pm |
| leedantex Member Since: 15 Sep 2014 Location: Manchester Posts: 7      | Cheers | ||
|  Mon Sep 15 2014 1:01pm |
| leedantex Member Since: 15 Sep 2014 Location: Manchester Posts: 7      | Okay so I have narrowed it down by hooking up to a computer and the faults are.
|  Thu Sep 18 2014 2:26pm |
| Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4532      | Have you tried emptying the drier? | ||
|  Thu Sep 18 2014 4:12pm |
| leedantex Member Since: 15 Sep 2014 Location: Manchester Posts: 7      | Tbh Mikey im nervous of getting to a point where I end up with a broken compressor off the vehicle and then im totally screwed. Or is it a doddle of a job? | ||
|  Thu Sep 18 2014 5:11pm |
| Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4532      | Remove the bottom cover, take out 6 bolts holding the end cap on, fish out the internals, refit cap.
|  Thu Sep 18 2014 5:29pm |
| leedantex Member Since: 15 Sep 2014 Location: Manchester Posts: 7      | When you say not recommended for long term use. What do you call long term? Is it not pointless then and just worth fitting a new compressor? | ||
|  Thu Sep 18 2014 5:43pm |
| Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4532      | It's your money   | ||
|  Thu Sep 18 2014 7:10pm |
| Posting Rules
