Home > Faults & Fixes > Suspension goes into 'Extended mode'
leedantex
United Kingdom 2005 Range Rover Sport TDV6 HSE Cairns Blue
Hello, new here and hoping I can find a solution.
I have an 05 RRS HSE. When I have the vehicle stopped and I try to put the air suspension into 'Access mode' the front will lower then before the back lowers I get a beep and the dash will have the message 'Suspension going to Extended mode' then when the front raises again the dash shows the message 'Suspension reset if obstruction clear'.
Now if i persist and try several times after 3 or 4 presses the vehicle will eventually stay in 'Access mode' but this re-occurs next time I wish to go into Access mode. Also when driving, occasionally (1 out of 5 journeys) the dash will illuminate and the message 'Suspension fault' will appear on the dash.
Any ideas?
Thanks.
Post #436505 Mon Sep 15 2014 11:51am
Disco_Mikey
More than likely a blocked air dryer, or a blocked exhaust valve Thumbs Up
Dryer can be replaced as a separate part, exhaust valve is not serviceable, and will need a new compressor
Post #436516 Mon Sep 15 2014 12:30pm
leedantex
Thanks for the reply.
Is there any way I can check either of these before I go buying new parts?
Post #436522 Mon Sep 15 2014 12:44pm
Bodsy
Site Sponsor
Maybe also a ride height sensor.
Have a look on the 4x4 info screen to see if one wheel goes lower than the others or if when you put it into access mode, if one corner flashes differently to the others. Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #436524 Mon Sep 15 2014 12:53pm
Disco_Mikey
The dryer can be emptied of its contents (silica gel and filters), and put together to test
They can actually be rebuilt with the kits available online. Some have had success with this, others not so lucky.
Post #436525 Mon Sep 15 2014 12:55pm
leedantex
Thanks Bodsy, I tried this yesterday and it SEEMS to be fine when on the 4x4 screen. The front 2 wheels lower at the same rate to access height then the back ones do not even try, they simply stay on normal mode height and the message pops up. There is no flashing or juddering on the 4x4 screen.
So Mikey if I remove the dryer tonight and take out the inards, put it back on without replacing the inards it should work if the problem does lie with the dryer? Also if this is the case I should try replacing the inards and then rebuilding the dryer.
Post #436532 Mon Sep 15 2014 1:25pm
Disco_Mikey
Yes to both counts Thumbs Up
Post #436537 Mon Sep 15 2014 1:58pm
leedantex
Post #436539 Mon Sep 15 2014 2:01pm
leedantex
Okay so I have narrowed it down by hooking up to a computer and the faults are.
" Air not exhausting and filling up too slowly"
I am pressuming I need a whole complete unit? And if so, I would liekly fit myself due to the expense of the part and ease of fitting, but, should I get a new unit for £550+ or a used unit with 1 month warranty from a breakers for around £200-240?
Thanks in advance
Post #436970 Thu Sep 18 2014 3:26pm
Disco_Mikey
Have you tried emptying the drier?
Post #436974 Thu Sep 18 2014 5:12pm
leedantex
Tbh Mikey im nervous of getting to a point where I end up with a broken compressor off the vehicle and then im totally screwed. Or is it a doddle of a job?
Post #436984 Thu Sep 18 2014 6:11pm
Disco_Mikey
Remove the bottom cover, take out 6 bolts holding the end cap on, fish out the internals, refit cap.
If it cures your issues, fit a new dryer. Not to be recommended for long term use
If it doesn't, it needs a compressor
Post #436988 Thu Sep 18 2014 6:29pm
leedantex
When you say not recommended for long term use. What do you call long term? Is it not pointless then and just worth fitting a new compressor?
Post #436989 Thu Sep 18 2014 6:43pm
Disco_Mikey
It's your money Thumbs Up
Post #437003 Thu Sep 18 2014 8:10pm
