Home > Maintenance & Modifications > Roof racks
DAVIS
United States 2006 Range Rover Sport 4.4 V8 HSE Giverney Green
Roof racks
I'm in the process of buying a kayak and I currently do not have a roof rack on my RRS. Any experience or recommendations on best buys?
Thanks, in advance Smile
Post #42631 Wed Jun 28 2006 11:22pm
RRUK
United Kingdom 2013 Range Rover Sport Supercharged Autobiography Stornoway Grey
Biggles used to have the LR roof rails on his, the only downside is that as soon as you want to fit rails of ANY type, the plastic runners on the roof panel are then PERMANENTLY altered.
That's what I understand to be the case anyway, if anyone knows otherwise I'd love to know. L319 D4 HSE
1998 110 TUM HS FFR Hard Top XD WOLF
1982 Series 3 SWB
Post #43547 Mon Jul 03 2006 5:12pm
d3matt
United Kingdom 2005 Range Rover Sport TDV6 SE Bonatti Grey
Yes that is correct. You have to drill holes in the plastic trim to access the nuts below. The rails are then bolted down to these.
See photos in my gallery and PDF instructions that I wrote http://www.rrsport.co.uk/gallery/thumbnails.php?album=169
I also understand that a new set of plastic runners only cost about Ģ25 anyway. I don't know if this is a pair or per side. Even so, when you come to sell your RRS, you could return the roof back to normal. I sold mine with the rails fitted, as the new owner preferred the look with the rails on. Matt
RRS ownership for 1 yr, then D3 for 2 yrs. Then cut back to old bangers and working my way back up through two Peugeots in 6 months. Now got Saab 9-5 2.3t and enjoying the performance!
Post #43549 Mon Jul 03 2006 5:18pm
DAVIS
Well, I may have solved the problem. I found this product and their testimonials would suggest it works. http://www.riversidecartop.com/products.html
The good news is no holes need to be drilled !
Post #43637 Tue Jul 04 2006 4:33am
Singletrack
Belgium 2006 Range Rover Sport TDV6 HSE Java Black
Davis...I would not touch those with a ten foot pole! Abrasion is the word that comes to mind. If you have any dust or grit on those large footpads, by the time to you get to wherever you're taking that kayak and back home again you'll have two large abrasion marks on your roof...the ideal carrier ensures you have no load contact with the paint on your car. Hence, rails, then cross bars, then your load.
I can't imagine that the roads out to kayaking country are all paved and smooth out in Tahoe....
I do find the LR roof rails ugly not to mention the limited option on cross bars. It's just a further irritant that the track needs to be drilled to fit them. 2006 Range Rover Sport TDV6 HSE, Java/Ebony/Cherry, Privacy, Sunroof, PTI, Premium Sound, SatNav, Cold Climate, Tow kit, CarStyle coded grill and vents, Tasmods, Stormers, JE Exhaust, Autobiography badge
Post #43638 Tue Jul 04 2006 6:26am
DAVIS
Singletrack,
Excellent observation, I too am concerned about damaging the finish. The instructions call out the potential for abrasion. The solution (they suggest) is to clean both the pads and roof in advance to insure this does not happen. Now, as a result of this project, I notice that virtually "every" SUV on the road comes equiped with roof racks. Next step, purchase a new set of diamond tip drills... Crying or Very sad
Post #43784 Tue Jul 04 2006 3:40pm
Maxarn58
Sweden 2006 Range Rover Sport TDV6 HST Java Black
Fantastic tutorial from D3matt!! Thumbs Up Bow down
I have been looking at LR:s IKEA-leaflet, not understanding it at all..
They should had let Mr Kampradīs team make it for them..
Now I can fit rails to my new (for me) RRS HSE(T) MY-06
that i drove home from the dealer today.. Very Happy Very Happy
What a ride..
Ulf As a rule, I always resist temptations,
unless they are irresistible.
My Ride: 2006 RRS HSE TVD6 Java Black/Cherry Woods with HST factoryfitted pack.
Post #326467 Fri Dec 30 2011 12:22am
