![]() | Home > Maintenance & Modifications > Roof racks |
RRUK Member Since: 10 Jun 2005 Location: Leicestershire Posts: 2587 ![]() ![]() ![]() |
Biggles used to have the LR roof rails on his, the only downside is that as soon as you want to fit rails of ANY type, the plastic runners on the roof panel are then PERMANENTLY altered.
d3matt Member Since: 12 Jul 2005 Location: Oxfordshire, UK Posts: 730 ![]() ![]() ![]() |
Yes that is correct. You have to drill holes in the plastic trim to access the nuts below. The rails are then bolted down to these.
DAVIS Member Since: 27 Dec 2005 Location: Genoa, Nevada Posts: 134 ![]() ![]() ![]() |
Well, I may have solved the problem. I found this product and their testimonials would suggest it works. http://www.riversidecartop.com/products.html
Singletrack Member Since: 07 May 2006 Location: Belgium - Lasne Posts: 330 ![]() ![]() ![]() |
Davis...I would not touch those with a ten foot pole! Abrasion is the word that comes to mind. If you have any dust or grit on those large footpads, by the time to you get to wherever you're taking that kayak and back home again you'll have two large abrasion marks on your roof...the ideal carrier ensures you have no load contact with the paint on your car. Hence, rails, then cross bars, then your load.
Singletrack,
Maxarn58 Member Since: 24 Dec 2011 Location: Stockholm Posts: 142 ![]() ![]() ![]() |
Fantastic tutorial from D3matt!! |
