![]() | Home > Technical > power steering problem |
alpaca Member Since: 09 Sep 2014 Location: Silicon Valley Posts: 83 ![]() ![]() ![]() |
Have you ever changed the fluid ? Easiest way is turkey baster. Make sure fluid is at correct level in reservoir (if ti is low that could be your problem). If fluid is dark - needs changing. Siphon out as much as possible. Refill reservoir to correct level with dealer fluid (or GM/AC Delco Cold Climate fluid - not sure if that is available in UK). Run car for a day - then do the same again. Once you have use the whole quart bottle - you should have mostly new fluid in the car. (Or go to indie and have them do a full flush if you want to spend more). Also check accessory drive belt is in good condition (no cracks, cuts, ribs still look good - not too smooth) - if that is slipping , it could also cause you problems. |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4518 ![]() ![]() ![]() |
Check the suspension ECU for fault code C1130.
hard2beat2014 Member Since: 14 Jun 2014 Location: cambridge Posts: 63 ![]() ![]() ![]() |
would that make the problem come and go |
The column would, and if the wiring was an intermittent issue, then yes again |
bottom uj on steering column , drives spot on now |
designboy Member Since: 03 Feb 2014 Location: whitehead co antrim Posts: 338 ![]() ![]() ![]() |
Mine is the same, but black fluid in the bottle. I had the indie swap it and it drove perfect a week. But back black agian |
