Home > Technical > power steering problem
hard2beat2014
United Kingdom 2005 Range Rover Sport TDV6 HSE Chawton White
hi , some times my rrs drives like a dream and then some times the power steering gets a bit stiff , 05 tdv6
Post #435842 Tue Sep 09 2014 10:55pm
alpaca
United States 2006 Range Rover Sport 4.4 V8 HSE Zambezi Silver
Have you ever changed the fluid ? Easiest way is turkey baster. Make sure fluid is at correct level in reservoir (if ti is low that could be your problem). If fluid is dark - needs changing. Siphon out as much as possible. Refill reservoir to correct level with dealer fluid (or GM/AC Delco Cold Climate fluid - not sure if that is available in UK). Run car for a day - then do the same again. Once you have use the whole quart bottle - you should have mostly new fluid in the car. (Or go to indie and have them do a full flush if you want to spend more). Also check accessory drive belt is in good condition (no cracks, cuts, ribs still look good - not too smooth) - if that is slipping , it could also cause you problems.
Post #435921 Wed Sep 10 2014 7:22pm
Disco_Mikey
Check the suspension ECU for fault code C1130.
If this is present, it is an issue with the sensor on the steering rack
If it is not, then usually the lower column is at fault
Post #435954 Wed Sep 10 2014 10:26pm
hard2beat2014
would that make the problem come and go
Post #435974 Thu Sep 11 2014 8:17am
Disco_Mikey
The column would, and if the wiring was an intermittent issue, then yes again
Post #436031 Thu Sep 11 2014 8:25pm
hard2beat2014
bottom uj on steering column , drives spot on now
Post #438303 Wed Oct 01 2014 8:36pm
designboy
United Kingdom 2007 Range Rover Sport TDV8 HSE Lux Stornoway Grey
Mine is the same, but black fluid in the bottle. I had the indie swap it and it drove perfect a week. But back black agian Sad
Post #450710 Sun Feb 01 2015 2:46pm
