![]() | Home > Technical > dynamic and sport mode |
| PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2796
If you select the 4 x 4 info screen on the infotainment centre it will give you a small 'I' icon next to the mode selected this gives you a more in-depth description of the DSC ( or any other mode you've selected ) the Sport mode allows the gears to be changed quicker enabling acceleration - hope this helps |
| fkarim Member Since: 14 Apr 2012 Location: London Posts: 2216
"Dynamic" special program sets up the suspension so that it is more responsive/active, ride becomes a bit stiff, less body roll as a result.
| Minshy Member Since: 06 Jun 2014 Location: Mottram Posts: 48 |
I have a 2013 RRS not new version.
I certainly notice bad road surfaces and bumps more in dynamic mode. I feel the difference even when I pay only a little attention. Also, when driving fast on twisty roads, the car feels more under control with less body roll. How "dramatic" the difference is ... that's subjective IMHO and depends on how sensitive you are to changes in ride quality. Current: Volvo XC90 T8 Inscription Pro PHEV with some optionals on top
^^^^ as above - don't use it very often but did today - ( when the mood takes |
Thanks for the replies.
| defender_uk Member Since: 08 Aug 2006 Location: North Yorkshire, Pickering Posts: 169
yep I use a fair bit the dynamic setting. Always switch on on motorway exits so I don't have to slow down much...(!) but there is a marked difference between that and standard mode. |
| All times are GMT |
