![]() | Home > In Car Electronics > Programme key to put lights on |
| Nsp1 Member Since: 01 Sep 2014 Location: Manchester Posts: 96
Hi all.
Thanks Peachy,
| PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2796
Ps - update the icon on your profile |
| martyn05 Member Since: 13 Feb 2014 Location: Derby Posts: 324
Programme by keeping the Land Rover button
Thanks Martyn,
Can change the settings as often as you like - you must be doing something incorrect |
As far as I know, you can change it to any of the options available, whenever you want to. If I get the chance today, I will try to set mine and let you know how I get on. 2006 RRS SC Bonatti Grey (the 55th car/van I have owned)
Thanks guys.
| garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1071
The handbook does say that the keys are not to be in the ignition and the when reprogramming the button, when the button is first pressed during the programming sequence the function already in the key will operrate.
| Danny.H Member Since: 25 Aug 2014 Location: Brechin, Angus Posts: 91
Worked a treat that guys cheers. |
It worked! Thanks Garrycol
But just another quick one.
Mine doesn't do that either NSP1, I tried for about 10 minutes and gave up, fronts work ok though. 2007 RRS 2.7 HSE - Java Black |
| All times are GMT |
