Home > In Car Electronics > Programme key to put lights on
Nsp1
United Kingdom 2006 Range Rover Sport TDV6 HSE Bonatti Grey
Hi all.
I've just taken delivery of my 2006 RRS yesterday am I'm new to this site so go easy on me!
I've never had a RR before so I'm obviously seeing what button do what and so on and currently when I press the Land Rover button on my my key fob the boot opens. I don't really have a need for this and instead would like the lights to come on. I've looked in the book and it says press and hold the button, flash the lights and that will programme it.
Problem is, when I press and hold the logo, the boot opens. I hear the beep from the dash and I flash the full beam but it doesn't re-programme it. The boot still unlocks when I press the logo. I'm getting a bit frustrated.
Can anyone help please?
Thanks in advance
Post #434820 Mon Sep 01 2014 1:38pm
PEACHY
Welcome to the forum Thumbs Up the upper tailgate is the default factory setting - I reprogrammed my 2005 to do what you need - trouble is its gone along with the manual Big Cry I do remember I did use the handbook as the guide Thumbs Up 16MY Estoril Blue SVR.............
Post #434884 Mon Sep 01 2014 9:36pm
Nsp1
Thanks Peachy,
I followed the manual but it didn't change it.
I just can't seem to get it to change.
Post #434891 Mon Sep 01 2014 9:54pm
PEACHY
Sad gutted I can't help - keep trying I'm sure that's how I did mine Thumbs Up I was bored one day & went through the different set ups - flashing lights - lowering suspension & tailgate open + 2 more - I'm sure there's 5 Question
Good luck - someone will be along in a while with the right answer Thumbs Up 16MY Estoril Blue SVR.............
Post #434895 Mon Sep 01 2014 10:10pm
PEACHY
Ps - update the icon on your profile Thumbs Up 16MY Estoril Blue SVR.............
Post #434896 Mon Sep 01 2014 10:10pm
martyn05
Programme by keeping the Land Rover button
pressed and also flashing the headlamps. A
chime from the instrument panel will confirm
successful programming.
A short press of the Land Rover button will now
cause the vehicle headlamps to illuminate for
the length of time specified in Settings. See
SELECTING SETTINGS OPTION, 81.
A second press of the button after three
seconds will deactivate the lamps. A further
press, within three seconds, will activate the
reverse lamps. A further press will deactivate
the headlamps and reverse lamps. 2006 RRS SC Bonatti Grey (the 55th car/van I have owned)
2005 GSX 1400 K5
Post #434909 Mon Sep 01 2014 11:12pm
Nsp1
Thanks Martyn,
I tried that but it didn't work. I heard the beep but when I press the button the boot still pops open.
Was just wondering if once you set it to something it couldn't be changed?
Post #434925 Tue Sep 02 2014 9:28am
PEACHY
Can change the settings as often as you like - you must be doing something incorrect Big Cry
Keep trying Thumbs Up 16MY Estoril Blue SVR.............
Post #434926 Tue Sep 02 2014 9:37am
martyn05
As far as I know, you can change it to any of the options available, whenever you want to. If I get the chance today, I will try to set mine and let you know how I get on. 2006 RRS SC Bonatti Grey (the 55th car/van I have owned)
2005 GSX 1400 K5
Post #434927 Tue Sep 02 2014 9:38am
Nsp1
Thanks guys.
Im obviously doing something wrong.
Post #434935 Tue Sep 02 2014 11:01am
garrycol
Australia
The handbook does say that the keys are not to be in the ignition and the when reprogramming the button, when the button is first pressed during the programming sequence the function already in the key will operrate.
So key out of the ignition.
Press and keep pressed the Landrover Button and in your case the tailgate will unlock (don't worry about it)
With the Landrover button still pressed, flash the headlamps until the chime sounds
Now programmed for lights and the open tailgate function should be over written.
Garry 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #434947 Tue Sep 02 2014 12:53pm
Danny.H
Scotland 2007 Range Rover Sport TDV6 HSE Java Black
Worked a treat that guys cheers. Thumbs Up
Post #434956 Tue Sep 02 2014 2:59pm
Nsp1
It worked! Thanks Garrycol
I was doing it with the keys in the ignition!
Post #434967 Tue Sep 02 2014 4:44pm
Nsp1
But just another quick one.
It says if you press the button again within 3 seconds the reversing lights come on.
Mine don't. Does anyone else's?
Post #435381 Fri Sep 05 2014 11:44pm
Danny.H
Mine doesn't do that either NSP1, I tried for about 10 minutes and gave up, fronts work ok though. 2007 RRS 2.7 HSE - Java Black
Post #435382 Fri Sep 05 2014 11:46pm
