Home > Technical > Brake pad warning notice
W18ODY
Hi, im going to buy a range rover tomorrow and whilst on the phone the bloke mentioned that the warning notice for the brake pad wear was on and had been on for about three weeks.
My question is does anyone know roughly how much meat is left on the pads when the sensor first comes on, obviously ill give them a physical look over but thought id inquire here first.
Thanks in advance.
Post #434762 Sun Aug 31 2014 9:52pm
PEACHY
Not enough Rolling with laughter seriously - welcome to the forum - Disco Mikey is the man he will put you in the picture Thumbs Up 16MY Estoril Blue SVR.............
Post #434764 Sun Aug 31 2014 9:56pm
W18ODY
Cheers for the reply peachy Smile
One thing ive been warned about is how much quicker these things go through discs and pads cause its stopping a hell of a lot more weight than the average hatchback!
As long as i can get it home ok ill be happy then i can change them out
Post #434766 Sun Aug 31 2014 10:02pm
MartyRRS
Australia 2008 Range Rover Sport TDV8 SE Alaska White
Hi, the brake pad warning came on my TDV8 a couple of weeks ago, the rears had done approx 60k and the fronts 38k and I thought 'fair enough'. Turned out it was a broken sensor and the fronts are still l'ike new' (the indy's words) and the rears still have around 20k left. I drive twisty hilly roads too so dont know about going through pads quicker than other cars. Cheers Regards, Marty
Now: 2008 RRS TDV8; 1975 Rangie ute
Then: 2010 Defender Puma TdCi 110; 1996 Defender 300Tdi; 1997 Disco V8 on vsi gas; 1976 Rangie 4.4l; 20 yrs of back breaking Tojos
Post #434773 Sun Aug 31 2014 10:58pm
fkarim
^^^ that's 38k and 24k in miles. Still impressive though.
I would stick a camera phone through the wheel's spokes, point to the inner side of the calliper (i.e. the side away from the edge of the disc) and take a photo (may need to use the flash). Gives a pretty good idea of how much is left.
Post #434775 Sun Aug 31 2014 11:48pm
Cooperm28
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Fuji White
Whilst painting my calipers this week on MY10 i noticed that only one side, the passengers side has the clip and wire attached to the brake for the wear indictor.
Are they easy to replace as it seems somewhere along the line the drivers side has been removed or broken off?
Post #434851 Mon Sep 01 2014 4:43pm
362bkr
United Kingdom 2012 Range Rover Sport SDV6 Autobiography Santorini Black
I would not dream of selling a car with a brake warning light on. I would be wondering what else the guy has not bothered to do ....
Post #434852 Mon Sep 01 2014 4:49pm
fkarim
There is only one front and one rear sensor. Front passenger side and rear driver side. The theory is left/right should wear evenly under normal circumstances.
Post #434856 Mon Sep 01 2014 5:08pm
Cooperm28
Thank you fkarim!
Post #434978 Tue Sep 02 2014 6:09pm
fkarim
You're welcome.
Post #434983 Tue Sep 02 2014 6:46pm
