![]() | Home > Maintenance & Modifications > Recommendation for a cheap(er) OBD reader to find a fault |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4506 ![]() ![]() ![]() |
You get what you pay for. Anything sub-£100 or so will only be a fancy OBD tool.
Ptang Member Since: 11 Jan 2008 Location: Bromley, Kent Posts: 95 ![]() ![]() ![]() |
Sorry it took so long to reply. Further investigation shows that it isn't the readers as such that are the problem but the software behind them - the cheap PC software out there doesn't seem to include Land Rovers (but you can get modules for GM, Ford or Mazda). As you said: fancy OBD tool.
Thebeloved Member Since: 09 Aug 2014 Location: Luxembourg Posts: 10 ![]() ![]() ![]() |
Hi Ptang,
Hi there,
Hi Ptang.
So I received the gadget yesterday and I tried to read my 2005 RRS suspension errors. I found 2 errors 100% matching and 1 error 33% matching. Here is what I found:
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9090 ![]() ![]() ![]() |
The rear corner valves are in a single valve block that lives on the left rear suspension turret. If you jack the left rear and remove the wheel you can see it. It's probably easier to get at if you remove the spare wheel and access it from that side. A new valve block is about £100.
Thank you for the quick answer. The information I got with the fault code reader is that it could be Electrical Fault. I will try to locate the cables that lead to the rear valve and see. Wish it is just a cable messing around. |
Bob. Member Since: 03 Feb 2009 Location: SWest Posts: 275 ![]() ![]() |
Hi Ptang
Replied |
UK Guy Member Since: 28 Nov 2010 Location: Staffs Posts: 149 ![]() ![]() ![]() |
Ptang
Finally I decided to take the car to the dealer to be fixed because I didn't have the right tools to lift the car to work under it.. And indeed they found the same codes as I found with my tool mentioned here. They repaired only the cables connected to the harness close to the valve. They charged me 489 eur. Including calibration. It hurt to pay that amount but it is too late. I just wanted to update you guys.
luciogodoy Member Since: 04 Feb 2014 Location: Windsor Posts: 6 ![]() ![]() |
Hi ptang
