Home > Maintenance & Modifications > Recommendation for a cheap(er) OBD reader to find a fault
Ptang
United Kingdom 2005 Range Rover Sport TDV6 HSE Zambezi Silver
Hi all,
I've got a yellow suspension warning light that comes on every now and then when driving on normal roads (message is "suspension fault - normal height only" if memory serves).
I've checked the battery's OK, the height sensors report they are OK (according to the touch screen display), did a full lock-to-lock just in case the steering sensor needed resetting and over night the car doesn't drop at all so I need to delve in a bit further.
Before I take the car over to have it looked at, I'd like to get an idea of what might be up (compressor etc). I'm looking for a cheap and cheerful OBD device that will let me know what's wrong - son number 2 born three weeks ago so not in the market for an IID Crying or Very sad
Can anyone point me at something sub-£100 that would fit the bill? I was thinking something like the OBDLink SX - will that do the trick in helping identify the problem?
Thanks in advance.
'tang
Post #426854 Wed Jun 11 2014 5:25pm
Disco_Mikey
You get what you pay for. Anything sub-£100 or so will only be a fancy OBD tool.
See if you can find a 2nd hand IID, and have it re-licensed Thumbs Up
Post #426862 Wed Jun 11 2014 6:00pm
Ptang
Sorry it took so long to reply. Further investigation shows that it isn't the readers as such that are the problem but the software behind them - the cheap PC software out there doesn't seem to include Land Rovers (but you can get modules for GM, Ford or Mazda). As you said: fancy OBD tool.
I looked into a 2nd hand IID but sill couldn't justify the cost (our baby takes all beer tokens at present).
I did however find a rather cheep £28 Mongoose Pro VCI from China - I'll be the first to admit that I can't be positive it's 100% genuine, however it is really really well engineered. I won't mention the software that was supplied with it but it was the latest v138, had all the July updates (VDF/SPA etc), identified the VCI perfectly first time and worked like a dream.
No matter what, I strongly advise purchasing only genuine products from reliable sources. This time I would say I was lucky - you never know what might have happened, I got my fault code and saved myself some £££ as I can change the compressor myself.
'tang.
Post #428907 Mon Jun 30 2014 2:14pm
Thebeloved
Luxembourg 2005 Range Rover Sport TDV6 HSE Santorini Black
Hi Ptang,
I am in the same situation as you. 100% exactly. 2months baby too Rolling Eyes .
Could you please recommend me one obd tool for a range rover sport 2005-2009?
I googled mongoose but not much info.
Thanks
Lahbib
Post #433696 Tue Aug 19 2014 10:17am
Ptang
Hi there,
Not sure if this breaks the forum rules, but this was the site I used to buy my VCI:
http://www.buyobdtool.com/wholesale/jlr-mo...-2014.html
You can take a look at my blog which tracks my dianostics and repair of my suspension compressor for an idea of what you can do with it - I haven't got around to finishing the blog for the repair but it's fixed and I'll do it when I get a spare moment.
http://trialsofarrsowner.wordpress.com/par...formation/
Hope this helps.
'tang.
Post #433702 Tue Aug 19 2014 12:02pm
Thebeloved
Hi Ptang.
Thanks a lot. I will check the device later.
I wish it doesn't break any rules.
Lahbib
Post #433703 Tue Aug 19 2014 12:07pm
Thebeloved
So I received the gadget yesterday and I tried to read my 2005 RRS suspension errors. I found 2 errors 100% matching and 1 error 33% matching. Here is what I found:
U0416-86 RLM INVALID DATA RECEIVED FROM VEHICLE DYNAMICS CONTROL MODULE. 100%
C1A34-01 RLM REAR RIGHT CORNER VALVE. 100%
U0300-55 SASM INTERNAL CONTROL MODULE SOFTWARE INCOMPATIBILITY. 33%
I am trying to locate the rear right valve to check it if it is ok or not. However I couldn't find anything online to help where to find it. Any help would be appreciated.
Post #434283 Wed Aug 27 2014 8:16am
The rear corner valves are in a single valve block that lives on the left rear suspension turret. If you jack the left rear and remove the wheel you can see it. It's probably easier to get at if you remove the spare wheel and access it from that side. A new valve block is about £100.
http://britishparts.co.uk/products/134963-...RVH000055G 2012 SDV6 - it's missing a couple of cylinders
Post #434293 Wed Aug 27 2014 8:54am
Thebeloved
Thank you for the quick answer. The information I got with the fault code reader is that it could be Electrical Fault. I will try to locate the cables that lead to the rear valve and see. Wish it is just a cable messing around. Rolling Eyes
Post #434328 Wed Aug 27 2014 5:11pm
Bob.
Hi Ptang
You have a PM
Bob
Post #435634 Mon Sep 08 2014 11:47am
Ptang
Replied Smile
Post #435908 Wed Sep 10 2014 6:25pm
UK Guy
England 2013 Range Rover Sport SDV6 Autobiography Santorini Black
Ptang
You have pm
UK Guy RRS HSE with a few extras & a
2013 RRS Autobiography
Post #435927 Wed Sep 10 2014 7:59pm
Thebeloved
Finally I decided to take the car to the dealer to be fixed because I didn't have the right tools to lift the car to work under it.. And indeed they found the same codes as I found with my tool mentioned here. They repaired only the cables connected to the harness close to the valve. They charged me 489 eur. Including calibration. It hurt to pay that amount but it is too late. I just wanted to update you guys.
Post #435929 Wed Sep 10 2014 8:07pm
luciogodoy
Hi ptang
Had the same issue as you did on my Disco 3, and fixed the compressor with epoxy.
Have a read on this post:
http://www.disco3.co.uk/forum/topic102168.html
Lucio
Post #435942 Wed Sep 10 2014 9:37pm
