![]() | Home > Maintenance & Modifications > Creaking suspension!! |
| Madasmad Member Since: 01 Mar 2013 Location: Crewe Posts: 37
My suspension creaks really badly usually after towing my caravan and much more so if the weather is warm and dry. Any ideas as this driving me mad! |
| Andi Member Since: 26 Jan 2014 Location: Here & There Posts: 263
Have you tried spraying some WD40 around the noisy area? |
Yes tried this but it doesn't last? It's that bad it turns heads as you go down the street! What doesn't kill you only makes you stronger!
| stevew Member Since: 16 Oct 2013 Location: solihull Posts: 75
Be interested to find out the cause of this as this happens to my RRS as well on hot dry days |
Generally, a creaky rear end is hub bushes.
It seems to be the front end as well Mikey. Any ideas for this?
ARB bushes/links seem to be guilty of creaks on the front, along with lower wishbones |
Thanks Mikey. What are your thoughts on poly bushes? What doesn't kill you only makes you stronger!
I fully polybushed a D3 once. Personally, I didn't like the way it drove. To bouncy, and a bit harsh. Also had an odd habit of lurching when stopping from low speeds.
Some bits here about it;
