Home > Maintenance & Modifications > Creaking suspension!!
Madasmad
My suspension creaks really badly usually after towing my caravan and much more so if the weather is warm and dry. Any ideas as this driving me mad! Big Cry What doesn't kill you only makes you stronger!
2008 RRS TDV8 330Bhp 800nm
Post #432198 Sun Aug 03 2014 6:42am
Andi
Have you tried spraying some WD40 around the noisy area?
Post #432199 Sun Aug 03 2014 7:03am
Madasmad
Yes tried this but it doesn't last? It's that bad it turns heads as you go down the street! What doesn't kill you only makes you stronger!
Post #432200 Sun Aug 03 2014 7:08am
stevew
United Kingdom 2009 Range Rover Sport Supercharged Zermatt Silver
Be interested to find out the cause of this as this happens to my RRS as well on hot dry days
Post #432204 Sun Aug 03 2014 8:47am
Disco_Mikey
Generally, a creaky rear end is hub bushes.
Would need to at least jack the back end up and check
Post #432205 Sun Aug 03 2014 8:56am
Madasmad
It seems to be the front end as well Mikey. Any ideas for this?
Thanks for all the replies. What doesn't kill you only makes you stronger!
Post #432207 Sun Aug 03 2014 9:05am
Disco_Mikey
ARB bushes/links seem to be guilty of creaks on the front, along with lower wishbones
Post #432208 Sun Aug 03 2014 9:08am
Madasmad
Thanks Mikey. What are your thoughts on poly bushes? What doesn't kill you only makes you stronger!
Post #432214 Sun Aug 03 2014 10:05am
Disco_Mikey
I fully polybushed a D3 once. Personally, I didn't like the way it drove. To bouncy, and a bit harsh. Also had an odd habit of lurching when stopping from low speeds.
Things may have improved after 1k miles or, once things had settled in, but it's not for me Thumbs Up
Post #432224 Sun Aug 03 2014 10:55am
Madasmad
Thumbs Up thanks Mikey Thumbs Up What doesn't kill you only makes you stronger!
Post #432228 Sun Aug 03 2014 11:42am
Andi
Some bits here about it;
http://www.rrsport.co.uk/forum/topic18183....suspension
http://www.rrsport.co.uk/forum/topic11806....suspension
http://www.rrsport.co.uk/forum/topic22389....suspension
Post #432230 Sun Aug 03 2014 11:54am
