![]() | Home > General > STOLEN |
jimbg Member Since: 29 Jan 2013 Location: No longer by the River Dart.... Posts: 1903 ![]() ![]() |
Yep!!!
BKHK Member Since: 05 May 2008 Location: Perth Posts: 1941 ![]() ![]() ![]() |
Mate, I am gutted for you. That is terrible.
Did wonder how long it would be before they moved on from lights and grills to complete cars. It begs the question, how do LR claim this is a Cat 1 alarm. It can't be if cars can be driven away without a key. Heart goes out to you, it's not a nice feeling, I came out to find my car on bricks in Hampstead, it turns out the local dealer had a set of masters lock keys stolen but never thought to warn locals. 2x TDV6. SE and HSE. Both returned to sender with issues👀
ravingmad Member Since: 23 May 2013 Location: Essex Posts: 331 ![]() ![]() ![]() |
Feel for you, unfortunately it seem this is no an uncommon event.
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9087 ![]() ![]() ![]() |
I think it highlights one of the problems with the current vogue for keyless entry/starting. Never did understand why pressing a button was better than turning a key that also happened to disable a physical lock as well as starting the engine. 2012 SDV6 - it's missing a couple of cylinders
Salmon&permit Member Since: 02 Aug 2014 Location: London & everywhere Posts: 36 ![]() ![]() |
Thanks for support. Yes, the police said the best defence in their view was a steering lock. So, back to my student days in Newcastle when when car(s) was stolen 6 times in 3 years........invariably brought return after a bit of joy riding......although they must have had a low threadshold for 'joy' if they found an Escort Diesel with 150k on the clock any fun to drive!!
And I suppose the next question is do I want another......and if so, do I go for the same again, or move to the V8 diesel or petrol engine. And why isn't the 3 litre petrol engine available in the UK? Thoughts welcome on that too.......or does that go in another post? |
MXSRR Member Since: 25 Aug 2013 Location: Lowestoft Posts: 228 ![]() ![]() ![]() |
It does not really matter how good an alarm/imobiliser system you have, if professional car thieves want it they will steal it |
viper Member Since: 21 Apr 2007 Location: chester le street Posts: 857 ![]() ![]() ![]() |
Feel for you hope you get a good outcome
martyn05 Member Since: 13 Feb 2014 Location: Derby Posts: 324 ![]() ![]() ![]() |
What you need is an isolator switch, cut the + wire to the starter motor then extend the wire to the switch (located somewhere in the car) then connect it back to the wire that goes to the starter motor. The car will not start if the isolator key is not inserted but the rest of the electrical systems should be fine.
That's sort of what the ignition key used to do...the idea of having keyless entry/starting but needing to put a cut off key in to a slot in order to start just seems a bit perverse. 2012 SDV6 - it's missing a couple of cylinders
RRS Daz Member Since: 23 Jan 2012 Location: Yorkshire Posts: 797 ![]() |
^^^^^^ I agree with martyn and we use a similar idea on our Ktm enduro bikes as they don't have keys. |
Also Clifford alarms used to come with a pin code you had to enter (used for anti hijack too) |
I guess one of the issues with the Sport is that it takes a while for the computer systems to shut down after the car's been locked. Consequently putting an isolator switch in the circuit which would then switch of battery power immediately might upset it.
