Home > General > STOLEN
martyn05
United Kingdom 2006 Range Rover Sport Supercharged Bonatti Grey
My idea was to leave the rest of the electrical system alone and only isolate the starter motor. If you isolate the battery it would cause lots of problems. 2006 RRS SC Bonatti Grey (the 55th car/van I have owned)
2005 GSX 1400 K5
Post #432218 Sun Aug 03 2014 9:34am
RRS Daz
You could go all James Bond with this modification and have a pop out panel with a hidden switch.
Post #432232 Sun Aug 03 2014 11:06am
Salmon&permit
Thanks for all the thoughts and feedback. No sign of car - and not expecting any. Will contemplate various cut off options, but suspect the best way forward will be along 'physical' protection line.....a dirty great retractable bollard in front of the car. Simple, not too expensive and not relying on not-so-clever electronics. Might even go for the old yellow steering clamp too....belt and braces, locking the stable door after the first horse has bolted, but hoping it will stop others going astray!
Post #432325 Mon Aug 04 2014 8:01pm
RRS Daz
Yeah drop posts are good, I've got one.
Post #432332 Mon Aug 04 2014 9:10pm
mlines
Has there been any indication on how they did it?
If it was a simple lift onto a flatbed and sort the electronics later then no electrical solution will prevent this.
Or are they scanning the keys etc. 2016 RRS 4.4 TDV8 Autobiography Dynamic in Montalcino Red and Stealth Kit
Post #432352 Tue Aug 05 2014 9:33am
Salmon&permit
Driven off - I saw it go after I heard them start it up. It has been suggested that the locking signal was 'blocked' when I locked it earlier in the evening. So, worth double checking that car actually locks when you instruct it to do so! Insurance company say there are some very professional and technolgy enabled eastern europeans knocking around, stealing to order and shipping out very quickly. Takes them less than a few minutes to get in and drive off..........and they know where to look in terms of where the typical tracking device is located. Hope this helps others avoid what has happended to me.....
Post #432374 Tue Aug 05 2014 11:59am
Pufftmw
Not everyone's cup of tea but I interrupted and re-routed the fuse lead (back of fusebox) for the fuel pump in a Subaru Impreza Turbo, to a hidden switch. No way that baby going to start unless you knew where the switch was...
Post #432385 Tue Aug 05 2014 1:08pm
