![]() | Home > General > front arc bush. |
Undo the 2 front bolts of the clamp, and remove the chassis member underneath to change the bush |
| scott1963 Member Since: 27 Jul 2014 Location: scotland Posts: 18
thanks for that.is it easy to take cross member off. |
Hi sorry i have the active cornering installed in my range rover sport anti roll bar.
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9156
Anything is possible if you have the money to spend. I doubt it would be cheap/easy to replace the dynamic roll bar as it's linked in to the overall stability control and terrain response systems.
Hi just thinking it would be cheeper to look after if anything went bad with the bar.£800 for a replacement,
Hi any chance of sending me a picture.I am offshore at the moment and i am going to attempt this task when i get home
| jochem00 Member Since: 16 Oct 2013 Location: Monaco Posts: 85 |
A M.G.B offshore? dayrater?
You can do away with the ARC system, but it would be cheaper to repair your issues
thanks for that.
| All times are GMT |
