Home > General > front arc bush.
scott1963
front arc bush.
can any one tell me a easy way to remove them.do i have to remove the front drive shaft in order to remove the bolts.holding the clamp on the bush on the passenger side.
or is there a easy way.
scott rr sport tdv6
Post #431745 Sun Jul 27 2014 7:42pm
Disco_Mikey
Undo the 2 front bolts of the clamp, and remove the chassis member underneath to change the bush Thumbs Up
Post #431762 Sun Jul 27 2014 10:31pm
scott1963
thanks for that.is it easy to take cross member off.
Post #431769 Mon Jul 28 2014 4:23am
scott1963
Hi sorry i have the active cornering installed in my range rover sport anti roll bar.
just a Qustion can i do away with this system and install a conventional anti roll bar.
my rr sport is a tdv6 07 plate.would there be any problems if i do this. Neutral
scott
Post #431770 Mon Jul 28 2014 4:38am
Anything is possible if you have the money to spend. I doubt it would be cheap/easy to replace the dynamic roll bar as it's linked in to the overall stability control and terrain response systems.
Why would you want to replace the dynamic bar with a passive one? 2012 SDV6 - it's missing a couple of cylinders
Post #431784 Mon Jul 28 2014 1:02pm
scott1963
Hi just thinking it would be cheeper to look after if anything went bad with the bar.£800 for a replacement,
£140 for new front bar and poly bush.
the cross member that you told me to take off to access the bush clamps is it a simple job to do.is this the same procedure for removing the active cornering clamps.
thanks
Post #431808 Mon Jul 28 2014 6:06pm
scott1963
Hi any chance of sending me a picture.I am offshore at the moment and i am going to attempt this task when i get home
just trying to get my head arround it.and prepair.
thanks scott.
Post #431810 Mon Jul 28 2014 6:32pm
jochem00
A M.G.B offshore? dayrater?
Why loose your valuable time back on the beach by saving a few pennies by doing it yourself!
Post #432089 Fri Aug 01 2014 12:51pm
Disco_Mikey
You can do away with the ARC system, but it would be cheaper to repair your issues
The crossmember is very easy to remove. Held on by 4 bolts.
Post #432114 Fri Aug 01 2014 6:50pm
scott1963
thanks for that.
will start job on monday
Post #432120 Fri Aug 01 2014 7:39pm
