![]() | Home > General > Hi new to this any help would be much appreciated. |
MXSRR Member Since: 25 Aug 2013 Location: Lowestoft Posts: 228 ![]() ![]() ![]() |
Possibly a blown fuse? Worth checking first |
rigpig100 Member Since: 30 Jul 2013 Location: angloa until the 18th !! Posts: 263 ![]() ![]() |
Have you checked all the fuses ? |
Try the obvious things first; check fuse 53 in the passenger compartment fuse box perhaps? The owners manual has instructions on how to access it. No tools required but small fingers or a pair of needle nose pliers make it easier to get the fuses out. If its not the fuse maybe charge up the battery and do a hard reset. |
Lauren_j23 Member Since: 27 Jul 2014 Location: Wales Posts: 8 ![]() ![]() |
Sorry, forgot to mention I tried the fuses. Also had someone to disconnect and reconnect the battery. What is a hard reset ? How do you do that. I've been looking online, does anyone think it could be related to the steering coupler ? The only thing is people have had problems prior, but I've had nothing, all has been working as should. :-s
Try resetting the Stereo itself.
Thank you all, done the reset and it's all working again |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2796 ![]() ![]() |
mark.b Member Since: 02 Oct 2013 Location: cheltenham Posts: 113 ![]() ![]() |
+1 |
Chris day Member Since: 31 Oct 2013 Location: Bexley kent Posts: 91 ![]() ![]() ![]() |
Nice one |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 954 ![]() ![]() ![]() |
Can't argue,,,,,,, a great bunch of knowledgeable people on this forum |
