![]() | Home > Technical > Vibration when accelerating - am i over analysing things |
Poss rear prop centre bearing.... 2008 G4 RRSport TDV8 current
wilpert Member Since: 25 Jun 2014 Location: London Village Posts: 169 ![]() ![]() ![]() |
Thanks for the reply,
If your unsure about an indi then try main dealer, I understand you can get the centre bearing after market but never fitted one so don't know what there like to fit.. 2008 G4 RRSport TDV8 current
Thanks,
Having had several discussions with wheel suppliers and garages etc.
gazzc Member Since: 07 Jan 2010 Location: cheshire Posts: 494 ![]() ![]() |
have your gearbox oil changed /flushed and add some doctor tranny sooner rather than later ,and im quite sure your vibration under load will be gone |
That sounds like a plan, as it's now so much better with just a slight shudder at around 50 mph and then again at much higher speeds, which I suspect really is to be expected.
