![]() | Home > Technical > Wing mirror/reverse |
| RRS_PAT Member Since: 16 Dec 2010 Location: South Posts: 176
Apologies if this is stating the obvious
What year is the car? Early ones had issues with memory modules |
| redson Member Since: 01 Feb 2014 Location: Surrey Posts: 36
Yes, I saved the setting to memory. The car is 2007 TDV8. |
| RossM Member Since: 27 Aug 2012 Location: Poulton-Le-Fylde, Lancashire Posts: 80
I have a 2007 and have similar issues with mirror memory and also seats. Are they both on the same memory module? 2007 Range Rover Sport TDV6 HSE- Cairns Blue with 22" Stormers |
Yes. I've followed the memory programming process using one memory button setting. Seat seems OK. When In reverse it seems OK, but when I then select drive the mirror now adjusts to another 'reverse' setting |
| C11RRJ Member Since: 23 Jun 2013 Location: Northumberland Posts: 17
+1 |
| riverblanche Member Since: 11 Jun 2011 Location: Retford'ish Posts: 1134
+1
There was a TSB about it, with chassis numbers etc. Will try and find it |
| Ned Kelly Member Since: 03 Mar 2014 Location: Great Yarmouth Posts: 12
I started to think I was going mad as I have the same issue. 2006 TDV6 |
| All times are GMT |
