![]() | Home > Technical > Wing mirror/reverse |
RRS_PAT Member Since: 16 Dec 2010 Location: South Posts: 176 ![]() ![]() ![]() |
Apologies if this is stating the obvious
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4529 ![]() ![]() ![]() |
What year is the car? Early ones had issues with memory modules |
redson Member Since: 01 Feb 2014 Location: Surrey Posts: 36 ![]() ![]() ![]() |
Yes, I saved the setting to memory. The car is 2007 TDV8. |
RossM Member Since: 27 Aug 2012 Location: Poulton-Le-Fylde, Lancashire Posts: 80 ![]() ![]() ![]() |
I have a 2007 and have similar issues with mirror memory and also seats. Are they both on the same memory module? 2007 Range Rover Sport TDV6 HSE- Cairns Blue with 22" Stormers |
Yes. I've followed the memory programming process using one memory button setting. Seat seems OK. When In reverse it seems OK, but when I then select drive the mirror now adjusts to another 'reverse' setting |
C11RRJ Member Since: 23 Jun 2013 Location: Northumberland Posts: 17 ![]() ![]() ![]() |
+1 |
+1
There was a TSB about it, with chassis numbers etc. Will try and find it |
Ned Kelly Member Since: 03 Mar 2014 Location: Great Yarmouth Posts: 12 ![]() ![]() ![]() |
I started to think I was going mad as I have the same issue. 2006 TDV6 |
