Home > Maintenance & Modifications > Ride height sensors and valve blocks
I'm trying to get to the bottom of a strange ride height issue on my TDV8 which I think is contributing to uneven tyre wear. Even after calibration using my IIDTool the ride height varies across the axles and does so dynamically with the rear being particularly noticeable.
I've ordered new sensors and all three valve blocks and I think I'll change them all and re-calibrate (and get yet another 4-wheel alignment done as hopefully a consistent ride height will mean the alignment will then be meaningful).
The question is, are there any "gotcha" issues to be aware of when changing these items? It all looks to be simple plug and play stuff but that always makes me nervous Embarassed
With the valve blocks, is it just a case of unscrewing the air lines from the block, pulling out the pipe and pushing it in to the new block? I understand that an olive might need removing from the pipe. Is this usually a tight fit? Thinking of the "fun" I've had with plumbing olives makes me winder if the pipe is likely to get damaged.
If the issue persists after this, I'll look at changing all of the spring/damper units too. Might be worth doing anyway as they're several years old now. 2012 SDV6 - it's missing a couple of cylinders
Post #421274 Mon Apr 14 2014 12:30pm
armitage_shanks
Australia 2010 Range Rover Sport TDV8 HSE Lux Java Black
Be careful with the electrical connectors to the sensors. The plastic locks tend to break on the loom side of the connectors when you disconnect the sensor.
Rolling Eyes
Post #421439 Wed Apr 16 2014 4:25am
Thanks, I'll watch out for that. 2012 SDV6 - it's missing a couple of cylinders
Post #421462 Wed Apr 16 2014 10:13am
Well that was annoying. Got it jacked up, wheels off, and couldn't get the bolts undone that hold the rear height sensors on. Even with a dose of WD40. Absolutely refuse to move. I don't want to force the issue however as it'll be fun changing them if the bolt heads get damaged so I've decided to put the wheels back on and leave it. I might have another look tomorrow to see if the WD40 has found its way along the full length of the thread.
The rear valve block is similarly a bit of a tight squeeze.
I'm thinking I shall just have to pay a garage to do the work. Bit annoying really. 2012 SDV6 - it's missing a couple of cylinders
Post #421642 Fri Apr 18 2014 2:38pm
RRS Daz
Blow lamp Thumbs Up
Post #421658 Fri Apr 18 2014 7:51pm
It's one option although perhaps a little overkill Thumbs Up
I went and picked up a set of 3/8-drive torx sockets and I'll see whether that works better in the morning after the WD40 has a few hours to do its work. The electrical connector was also impossible to undo but might be easier to manipulate once the sensor is off the bracket. 2012 SDV6 - it's missing a couple of cylinders
Post #421661 Fri Apr 18 2014 8:10pm
RRS Daz
Using a blow lamp isnt overkill, just warm it slightly and it will come straight out.
Post #421662 Fri Apr 18 2014 8:20pm
I've done that on bigger stuff once that I could get to easily but to get it in amongst the suspension looks to be a bit tricky. I don't have a torch just a burner-on-bottle type lamp that I use for the odd bit of plumbing.
A friend suggested smacking a slightly bigger bit in to the head of the torx bolt and then turning it. Again, this seems a bit "if nothing else works try it" type method.
It's not the end of the world if I can't get it to shift - I'll just get someone else to do it. Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #421668 Fri Apr 18 2014 8:43pm
RRS Daz
Yeah having a blow lamp that you can adjust is important if its in a tricky location.
Just hitting it can shock the bolt loose, so its not a last option id suggested a lot of wd40 or similar and a love tap with the hammer to shock the rust loose.
Worse can yeah pay someone but its not something i like to do Whistle
Post #421671 Fri Apr 18 2014 8:51pm
No, paying for a "simple" fix is not something I like doing either. But there's no point getting older if you don't get a bit wiser with it... Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #421676 Sat Apr 19 2014 12:43am
idrabble
Australia
I hope the WD40 works for you but if it doesn't get some proper penetrating oil, WD40 is primarily a water displacing spray with limited penetrating properties.
Post #421686 Sat Apr 19 2014 8:21am
