![]() | Home > Technical > front crank oil seal |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4527 ![]() ![]() ![]() |
Are you pushing the seal all the way into the recess in the casing? |
gazzc Member Since: 07 Jan 2010 Location: cheshire Posts: 494 ![]() ![]() |
pushed it in until it was flush with outer oil pump casing |
Does it leak immediately which would suggest incorrect fitting or damage to the lip of the seal.
both times it has leaked straight away,but i was very carefull fitting it |
Just had a thought..I had the crank hardened as advised but the crank swells when hardened would that be enough to cause a problem with the seal ..if so what would I do silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
If the crank had swollen, it should have a tighter seal on the inner edges of the oil seal. |
Barryp Member Since: 05 Nov 2011 Location: Sydney Posts: 261 ![]() ![]() ![]() |
Could there be a score on the casting that it fits into allowing oil around the outside?
possibly Barry,i will check everything in depth this time as i dont want to have to do it again |
[quote="Disco_Mikey"]If the crank had swollen, it should have a tighter seal on the inner edges of the oil seal.[/if so do you think it would swell so much that it would be damaging the seal or am i barking up the wrong tree |
Do you know that the engine crankcase is not pressurising - it should have negative pressure. A quick check can be done by taking off the oil filler cap and placing the palm of your hand over it and feel if there's suction - with engine running any pressure will make seals leak - (this was a common fault on engines where the PCV valves were blocked)!
hi ,thanks for reply,think i might try the sellotape tip,yes i am fitting it the right way(i hope)i did grease it up both times and it seemed to slide on quite nicely,only thing im not to sure about is as Mikey said i pushed it flush with the casing and didnt try to get it on any further so i might try and drift it on as far as poss |
If you put it in as far as it will go, it will leak, as it partially blocks the drain hole. That's why I asked |
ahh you really are the voice of experiance |
harrygh60 Member Since: 16 Nov 2011 Location: London Posts: 395 ![]() ![]() ![]() |
Hi Gazz, Is this a big job? what has to be removed to access the crankshaft pully. itisme |
