![]() | Home > Technical > front crank oil seal |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4527 ![]() ![]() ![]() |
Front timing belt off.
You asked what had to be removed to get to the crank pulley. Answer is an my previous post |
flack Member Since: 24 Feb 2013 Location: Preston Posts: 379 ![]() |
The new Oil pump housings are now different in design not just in being beefed up but also on the front Oil seal seating, as DM correctly quoted a 1mm proud step on the seal for the old type casings. The new casings have two lips now that stop you inserting it to far in to the oil pump housing so it is now knocked in until it's about level or just shy of the casing.
erickwan Member Since: 27 Mar 2016 Location: P Jaya Posts: 148 ![]() ![]() |
I need to install a front crank seal next week. Just to clarify, the RRS workshop manual stated the seal is 1mm under-flush with the face of the oil pump. I take that to mean that the seal sits deeper than the oil pump face. To my rudimentary understand of the English language, "proud of" means protruding, "flush" means level, "under flush" means deeper than. Gotta make sure I get this right first time. ![]() |
