![]() | Home > General > HELP - tailgate jammed with strut sticking out! |
RossM Member Since: 27 Aug 2012 Location: Poulton-Le-Fylde, Lancashire Posts: 80 ![]() ![]() ![]() |
I've just gone to change the tailgate struts on my sport and the tailgate slammed down as I removed on end of the gas strut leaving the strut sticking out of the side and the tailgate locked and jammed. I've tried master lock unlock trick but no luck, it's well jammed. Is there any other way to get the tailgate released. Panicking now as the strut is stuck between bodywork and tailgate glass and it all seems under tension! Tried opening tailgate glass only but no luck. 2007 Range Rover Sport TDV6 HSE- Cairns Blue with 22" Stormers |
Can't press too hard as strut may break the glass! 2007 Range Rover Sport TDV6 HSE- Cairns Blue with 22" Stormers |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2796 ![]() ![]() |
If possible push around the area of the lock only - is the car doors locked - could you not get someone inside to take the strain off the strut |
Panic over, fixed it! Phew! Thanks guys 2007 Range Rover Sport TDV6 HSE- Cairns Blue with 22" Stormers |
how ??? |
Following the gently putting pressure on the boot and pressing the release button. I had images of the tailgate glass shattering! 2007 Range Rover Sport TDV6 HSE- Cairns Blue with 22" Stormers |
