Home > General > HELP - tailgate jammed with strut sticking out!
RossM
United Kingdom 2007 Range Rover Sport TDV6 HSE Cairns Blue
I've just gone to change the tailgate struts on my sport and the tailgate slammed down as I removed on end of the gas strut leaving the strut sticking out of the side and the tailgate locked and jammed. I've tried master lock unlock trick but no luck, it's well jammed. Is there any other way to get the tailgate released. Panicking now as the strut is stuck between bodywork and tailgate glass and it all seems under tension! Tried opening tailgate glass only but no luck. 2007 Range Rover Sport TDV6 HSE- Cairns Blue with 22" Stormers
Post #418784 Sat Mar 22 2014 5:33pm
PEACHY
Shocked Have you tried pushing down on the tailgate - taking the tension off the strut - do this whilst locking then unlocking the RRS Sad
Good Luck. 16MY Estoril Blue SVR.............
Post #418785 Sat Mar 22 2014 5:39pm
RossM
Can't press too hard as strut may break the glass! 2007 Range Rover Sport TDV6 HSE- Cairns Blue with 22" Stormers
Post #418786 Sat Mar 22 2014 5:40pm
PEACHY
If possible push around the area of the lock only - is the car doors locked - could you not get someone inside to take the strain off the strut Question 16MY Estoril Blue SVR.............
Post #418787 Sat Mar 22 2014 5:42pm
RossM
Panic over, fixed it! Phew! Thanks guys 2007 Range Rover Sport TDV6 HSE- Cairns Blue with 22" Stormers
Post #418788 Sat Mar 22 2014 5:45pm
PEACHY
how ??? Thumbs Up 16MY Estoril Blue SVR.............
Post #418789 Sat Mar 22 2014 5:46pm
RossM
Following the gently putting pressure on the boot and pressing the release button. I had images of the tailgate glass shattering! 2007 Range Rover Sport TDV6 HSE- Cairns Blue with 22" Stormers
Post #418790 Sat Mar 22 2014 5:52pm
PEACHY
Bow down Bow down you wont do that again in a hurry Thumbs Up 16MY Estoril Blue SVR.............
Post #418791 Sat Mar 22 2014 5:53pm
