Home > Maintenance & Modifications > EGRs Blanked.
Chris day
EGRs Blanked.
We'll I just blanked my EGR valves off using the 2 blanking plate method. (£5 on eBay) It only took about 45 minutes. Although there was not a problem showing on dash I can already feel things are running better and showing 2 mpg more around town. So today is a good day and I never have to worry about EGRs again Very Happy Very Happy
Post #415587 Wed Feb 26 2014 12:49pm
Haybale
England 2007 Range Rover Sport TDV8 HSE Stornoway Grey
Shame you can't do this on the TDV8 Sad
Post #415594 Wed Feb 26 2014 2:05pm
Chris day
That is the down side to owning the TDV8 but iv been told there a lot highs to owning one too. Iv never had the the chance to drive one but maybe one day!
Post #415597 Wed Feb 26 2014 2:18pm
mad-dafty
Scotland 2010 Range Rover Sport 3.0 TDV6 Autobiography Stornoway Grey
I had Disco_Mikey blank the EGR valves on mine a few weeks back and I can feel a real difference to the car. I had no faults showing either. Blanking seems to have cut out that few seconds hesitation I used to get between slowing down and then entering traffic at a roundabout. A job well worth doing in my opinion. Thumbs Up 2010 RRS TDV6 3.0 Autobiography - Stornoway Grey
2006 RRS TDV6 2.7 HSE -Java Black
2008 BMW 3 Series 2.l
2006 BMW 5 series 2.l
Post #415600 Wed Feb 26 2014 2:45pm
Chris day
Same here' defiantly seems to drive better and it does seem to be more responsive at low speed.
So we'll done us Thumbs Up
Post #415609 Wed Feb 26 2014 4:03pm
SRE
Spain
Load of info on the Disco Forum, Pete (BAS) has a fix in place for euro 4 cars that is just about to be released In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #415621 Wed Feb 26 2014 6:09pm
The BAS fix has been in the pipeline for quite a while now. Is he actually about to release it or is it "coming soon"?
I'm hoping it's imminent because I want to fit it to my TDV8 if at all possible. Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #415623 Wed Feb 26 2014 6:39pm
Disco_Mikey
TDV8 is his next project, IIRC Thumbs Up
If you noticed a difference after blanking your EGR's, then you already had an EGR issue.
Blanking does not improve performance, it only restores the performance the car had lost Thumbs Up
Post #415660 Wed Feb 26 2014 9:54pm
I reckon my EGRs are causing a problem - the motor can be a bit lethargic at times. I also want to get a mega flush done on my gearbox but it looks like I'll need to travel to Bristol to get it done. Can't find anywhere near to Oxford/Banbury/Northampton that does it - a number of places mention it but actually they just do a double flush. 2012 SDV6 - it's missing a couple of cylinders
Post #415665 Wed Feb 26 2014 10:11pm
Chris day
My EGRs must of been starting to pack up. It did feel a little lazy at times. But seems better now!
Post #415669 Wed Feb 26 2014 10:23pm
rich_z3
United Kingdom 2010 Range Rover Sport TDV8 Autobiography Santorini Black
RRS 56 plate
Just ordered the egr blanking plates on eBay , but will the work on a 56 plate RRS , it was registered sept 06 ?
Post #415678 Wed Feb 26 2014 11:03pm
Disco_Mikey
Its right on the changeover. Will need to check with your chassis number.
If it is a 6A, then it will work. If it is a 7A, then it may not work.
Post #415682 Wed Feb 26 2014 11:11pm
rich_z3
It says 6a , thanks mikey
Post #415683 Wed Feb 26 2014 11:17pm
Chris day
That's lucky Thumbs Up
Post #415684 Wed Feb 26 2014 11:20pm
Disco_Mikey
Post #415686 Wed Feb 26 2014 11:25pm
