![]() | Home > Maintenance & Modifications > EGRs Blanked. |
Haybale Member Since: 25 Jul 2013 Location: Co Durham Posts: 30 ![]() ![]() ![]() |
Shame you can't do this on the TDV8 |
Chris day Member Since: 31 Oct 2013 Location: Bexley kent Posts: 91 ![]() ![]() ![]() |
That is the down side to owning the TDV8 but iv been told there a lot highs to owning one too. Iv never had the the chance to drive one but maybe one day! |
mad-dafty Member Since: 28 Oct 2013 Location: Glasgow Posts: 298 ![]() ![]() ![]() |
I had Disco_Mikey blank the EGR valves on mine a few weeks back and I can feel a real difference to the car. I had no faults showing either. Blanking seems to have cut out that few seconds hesitation I used to get between slowing down and then entering traffic at a roundabout. A job well worth doing in my opinion. |
Same here' defiantly seems to drive better and it does seem to be more responsive at low speed.
Load of info on the Disco Forum, Pete (BAS) has a fix in place for euro 4 cars that is just about to be released In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9087 ![]() ![]() ![]() |
The BAS fix has been in the pipeline for quite a while now. Is he actually about to release it or is it "coming soon"?
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4502 ![]() ![]() ![]() |
TDV8 is his next project, IIRC |
I reckon my EGRs are causing a problem - the motor can be a bit lethargic at times. I also want to get a mega flush done on my gearbox but it looks like I'll need to travel to Bristol to get it done. Can't find anywhere near to Oxford/Banbury/Northampton that does it - a number of places mention it but actually they just do a double flush. 2012 SDV6 - it's missing a couple of cylinders
My EGRs must of been starting to pack up. It did feel a little lazy at times. But seems better now! |
rich_z3 Member Since: 16 Feb 2014 Location: Runwell, essex Posts: 68 ![]() ![]() ![]() |
Just ordered the egr blanking plates on eBay , but will the work on a 56 plate RRS , it was registered sept 06 ? |
Its right on the changeover. Will need to check with your chassis number.
It says 6a , thanks mikey |
That's lucky |
