![]() | Home > Technical > N/S/F Hub Bent - Anyone help?????? |
Is the wheel buckled?
Harry HST Member Since: 09 Feb 2010 Location: Birmingham Posts: 296 ![]() ![]() ![]() |
With the wheel off the hub is quite clearly at an angle still compared to the other side with the wheel off.
adigorn Member Since: 18 Mar 2010 Location: Birmingham Posts: 110 ![]() ![]() ![]() |
Strange that garage can not fix it (they have a car so they can see what is wrong)
Visually Cannot see anything damaged only option now is 4 wheel alignment tomorrow |
as there is no adjustment at the top
This garage doesn't have the facilities for alignment, this needs to be done by a 4 wheel alignment company via camber caster which will draw the wheel in.
mike_D_3781 Member Since: 09 May 2013 Location: west Yorks Posts: 98 ![]() ![]() |
Hope it's not an expensive one.
Its already cost me £700 up until now due to needing a new alloy as well as part and labour.
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9097 ![]() ![]() ![]() |
How fast was she going when she hit the kerb? Must have been some impact! 2012 SDV6 - it's missing a couple of cylinders
Hope you get it sorted. Make sure you ban the Mrs from driving your sport from now on. |
Flipping eck, must've been some wack.
She's definitely banned mate this is costing me an arm and a leg!
