Home > Technical > N/S/F Hub Bent - Anyone help??????
Harry HST
United Kingdom 2005 Range Rover Sport 4.4 V8 HSE Java Black
Hi All
My wife had a little accident in my RRS over the weekend and has hit a Kurb very hard and has caused the wheel to bend in at an angle.
I have had a garage change the lower suspension arm, anti roll bar link, upper arm and the Hub and the problem is still there Big Cry
Anyone else any ideas???
Post #414437 Mon Feb 17 2014 7:59pm
Is the wheel buckled?
I presume you'll need to get the car properly aligned again too following the fitment of the new parts. ON THE WAY: BMW F21 M140i
Post #414438 Mon Feb 17 2014 8:16pm
Harry HST
With the wheel off the hub is quite clearly at an angle still compared to the other side with the wheel off.
Wheel is buckled and not been used at all, have been using two other alloys and one side is much out than the other.
Alignment will have to be done but surely the wheel wouldn't be this far out? Would it?
Post #414451 Mon Feb 17 2014 9:26pm
adigorn
United Kingdom 2007 Range Rover Sport TDV6 HSE Cairns Blue
Strange that garage can not fix it (they have a car so they can see what is wrong)
You did not mention steering rack - ?
any damage to frame ?
is it ok
Post #414468 Tue Feb 18 2014 12:24am
Harry HST
Visually Cannot see anything damaged only option now is 4 wheel alignment tomorrow Big Cry
Post #414470 Tue Feb 18 2014 12:35am
adigorn
as there is no adjustment at the top
(i understand the wheel is either too far in or out on the bottom)
bottom adjustments bolts are now new and free so theoretically
the guys should be able to straighten it by using them (visually at least)
I am afraid the alignment is not going to change it more than garage can
(it would be easier if you have a pic.)
Post #414475 Tue Feb 18 2014 7:37am
Harry HST
This garage doesn't have the facilities for alignment, this needs to be done by a 4 wheel alignment company via camber caster which will draw the wheel in.
Will find out today how we get on.
Post #414497 Tue Feb 18 2014 11:11am
mike_D_3781
Hope it's not an expensive one.
Post #414504 Tue Feb 18 2014 12:42pm
Harry HST
Its already cost me £700 up until now due to needing a new alloy as well as part and labour.
Waiting for the alloy to come in today in order to get the alignment done cant think what else it could be if the alignment doesn't pull it in
Post #414506 Tue Feb 18 2014 12:59pm
How fast was she going when she hit the kerb? Must have been some impact! 2012 SDV6 - it's missing a couple of cylinders
Post #414524 Tue Feb 18 2014 2:16pm
Hope you get it sorted. Make sure you ban the Mrs from driving your sport from now on. Whistle
Post #414527 Tue Feb 18 2014 2:35pm
mike_D_3781
Flipping eck, must've been some wack.
My pals mrs swerved to avoid running a cat over, and demolished the near side alloys, and cracked both offside, they were a Kahn special, cost him another £3.5k!
Any news yet?
Post #414544 Tue Feb 18 2014 5:16pm
Harry HST
She's definitely banned mate this is costing me an arm and a leg!
No news yet recovery got stuck in traffic getting there so the car wont be looked at until tomorrow.
Sad
Post #414563 Tue Feb 18 2014 7:15pm
