![]() | Home > General > Timed Climate & RPH |
muddywheels Milk Float Man Member Since: 01 Jul 2010 Location: East Riding of Yorkshire Posts: 5644 ![]() ![]() |
I have used my timed climate and it comes on but unless outside temp is very low (below about 5-7 deg) it just blows cold air |
rigsby Member Since: 20 Apr 2012 Location: Portsmouth Posts: 879 ![]() ![]() |
Hi Bomber, did you make sure they activated the timed climate(obviously did as you have the icon) and the remote option, there are 2 things that have to be activated. 1 for screen and 1 for remote? MY16 AUTOBIOGRAPHY Indus silver with some toys
Bomber H Member Since: 17 Apr 2012 Location: Abingdon / Reading Posts: 200 ![]() |
Rigsby, what would the remote option be called within the cars on board system?
Hi Bomber, do a search for a thread by rstebbings. The thread is called "timed climate - upgrade" and it has a picture of the settings on there. The feature that needs to be turned on within the timed climate screen is "call start" and this is the remote fob bit. Rigsby MY16 AUTOBIOGRAPHY Indus silver with some toys
Thanks |
Sounds like "call start" could be the equivalent. Worth giving it a try before you leave the indi |
There are three options on the drop down usually when enabling.
muddywheels have you got remote park heating in your car now? Timed climate (already present in HSE Black) isn't of much use to me (irregular car usage pattern) but remotely firing it up on demand is much more practical.
Fkarim - I'm sure mse has done it. If he sees this in sure he'll comment |
Thanks BC. Will send him a PM when the parts arrive and my car comes back too |
aljo Member Since: 13 Jun 2006 Location: West Sussex Posts: 3243 ![]() ![]() ![]() |
You need to edit the CCF and the EUCD
Thanks aljo. Will enable these settings and great tip about letting the car go to sleep - didn't know that. |
Sorry just seen this fkarim |
Unbeilievably easy to fit |
