Home > General > Timed Climate & RPH
Page 1 of 4 1234>
Bomber H
Timed Climate & RPH
I've fitted all the bits, and had things activated but could do with a little advice from those who use the systems please...
Timed Climate;
This is now on my touch screen so that should all work fine, but what is the minimum ambient temperature at which it will work (manual refers to 'low' ambient temperatures)?
Remote Park Heating;
I've installed the receiver and antenna in the boot area, and understand that my dealer activated whatever they needed too (Timed Climate now shows). When I've tried to turn it on remotely, the LED on the remote just flashes red then goes out - suggesting that signal is not received. I paired the remote before any activation was done, should I do it again? Also, if its too warm would the RPH function simply not work? 2016 VW Golf GTD DSG
2007 Exige S British GT SE
Gone : 2011 3.0TDV6 HSE, Stornoway Grey, Ivory, Piano Black Trim, Paddleshift, Privacy Glass, Side Steps, Mud Flaps, Heated Steering Wheel, Timed Climate & Remote Park Heating Smile
Post #413493 Tue Feb 11 2014 3:00pm
muddywheels
Milk Float Man
I have used my timed climate and it comes on but unless outside temp is very low (below about 5-7 deg) it just blows cold air Rolling Eyes
Centre AC knob flashes red light to show heater is on and not just blower Thumbs Up Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #413494 Tue Feb 11 2014 3:06pm
rigsby
Hi Bomber, did you make sure they activated the timed climate(obviously did as you have the icon) and the remote option, there are 2 things that have to be activated. 1 for screen and 1 for remote? MY16 AUTOBIOGRAPHY Indus silver with some toys
2012 3.0 SDV6 Luxury gone, but a great motor
Post #413580 Tue Feb 11 2014 10:40pm
Bomber H
Rigsby, what would the remote option be called within the cars on board system?
There does seem to be a bit of a language barrier when it comes to me asking them to activate 'remote park heating' to the dealer identifying the correct box to tick within the system.
The more black and white I can be, then the easier it will be to establish if they've done the right thing. 2016 VW Golf GTD DSG
Post #413593 Tue Feb 11 2014 11:38pm
rigsby
Hi Bomber, do a search for a thread by rstebbings. The thread is called "timed climate - upgrade" and it has a picture of the settings on there. The feature that needs to be turned on within the timed climate screen is "call start" and this is the remote fob bit. Rigsby MY16 AUTOBIOGRAPHY Indus silver with some toys
Post #413609 Wed Feb 12 2014 9:00am
Bomber H
Thanks Thumbs Up
The screen icon for timed climate appears to be different to mine (presumably because yours and rstebbings cars are the later SDV6 model), but hopefully 'call start' is the same within the configurator for my'11. I'll discuss with my indi.
Timed climate worked perfectly this morning Smile 2016 VW Golf GTD DSG
Post #413622 Wed Feb 12 2014 10:13am
rigsby
Sounds like "call start" could be the equivalent. Worth giving it a try before you leave the indi Thumbs Up MY16 AUTOBIOGRAPHY Indus silver with some toys
Post #413627 Wed Feb 12 2014 10:35am
mse
There are three options on the drop down usually when enabling.
Off
Timed Climate
Timed Climate + Remote.
The language may change, but the third option carries more in it and as such should be easy to identify. Mike
2014 Facelift Discovery
Post #413686 Wed Feb 12 2014 5:08pm
fkarim
muddywheels have you got remote park heating in your car now? Timed climate (already present in HSE Black) isn't of much use to me (irregular car usage pattern) but remotely firing it up on demand is much more practical.
I have ordered the parts but looks like no one on here has done it on the run-out model unless I have missed it. Wondering if it would be the same as MY12 cars that didn't have timed climate enabled as standard. Should be the same but great if someone can confirm. I should have asked the question before buying the parts Embarassed
Post #414084 Fri Feb 14 2014 11:50pm
Fkarim - I'm sure mse has done it. If he sees this in sure he'll comment Smile ON THE WAY: BMW F21 M140i
Post #414085 Fri Feb 14 2014 11:54pm
fkarim
Thanks BC. Will send him a PM when the parts arrive and my car comes back too Sad
Post #414086 Sat Feb 15 2014 12:19am
aljo
You need to edit the CCF and the EUCD
CCF heating and Ventilation Park heater enabled.
EUCD --EUCD Heating and Ventilation Additional Heater: Fuel Fired Park Heater FFPH
EUCD--EUCD Heating and Ventilation--Call start of parking heater: Call start of Parking heater accessory only ( via radio only)
If you are using a remote blipper then change the last setting to that setting.
But remember to let the car go to sleep afterwards..
Thanks to flack for this Thumbs Up works perfectly on my car
Post #414089 Sat Feb 15 2014 1:17am
fkarim
Thanks aljo. Will enable these settings and great tip about letting the car go to sleep - didn't know that.
Post #414094 Sat Feb 15 2014 9:20am
muddywheels
Milk Float Man
Sorry just seen this fkarim Embarassed
I went for remote fitted but due to quoted price being massively different when I got there cancelled it and not done it - like you timed is not a lot of use to me Sad
I may also buy parts and fit myself one day if simple enough Bow down Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #414099 Sat Feb 15 2014 9:55am
aljo
Unbeilievably easy to fit Thumbs Up
Hardest part was filling the kettle up for a cuppa Whistle
Post #414100 Sat Feb 15 2014 10:01am
Page 1 of 4 1234>
