![]() | Home > General > Paddle shift ??? |
Hayden Member Since: 10 Nov 2013 Location: Isle of Wight Posts: 87 ![]() ![]() ![]() |
Someone will probably confirm soon, but I'm sure u hold the +paddle for a few seconds.... |
^^^ This |
The man is correct pull and hold the paddle. I think both can be used although I only tried the plus one on loaner. 2x TDV6. SE and HSE. Both returned to sender with issues👀
JasM Member Since: 02 Nov 2012 Location: Lanarkshire Posts: 1186 ![]() ![]() ![]() |
Thanks |
I can't remember if you can do the '-' as well or not. |
yorky22 Member Since: 13 Sep 2013 Location: york Posts: 50 ![]() ![]() ![]() |
Thanks All will give it a go when i get home
codfather Member Since: 13 Feb 2010 Location: ayr Posts: 1171 ![]() ![]() ![]() |
Quickest way is just to knock the gear leaver across into sport then back again, works for me if I catch the paddle with my hand on it at say a junction. You can of course pull on the + paddle to get it up a gear or two before composing yourself let it switch itself off after 10 secs or so. The handy thing is that it won't go into a gear it's not happy with so shouldn't over rev
The OP has a 2012 RRS ,so no gear lever. 2014 L405 SDV8 RR Autobiography |
Andrew Member Since: 16 Jun 2005 Location: Cheltenham Posts: 248 ![]() ![]() ![]() |
You can hit the rev limiter in paddle shift configuration in RRS2 ! 5.0 Ltr Superchrged RRS2, Chile Red, Sideways out of junctions!
muddywheels Milk Float Man Member Since: 01 Jul 2010 Location: East Riding of Yorkshire Posts: 5642 ![]() ![]() |
I normally rotate knob to S and back to resume Auto - it will also do it automatically after a while but I will try holding paddle next time |
rigpig100 Member Since: 30 Jul 2013 Location: angloa until the 18th !! Posts: 263 ![]() ![]() |
the paddle shift brigade, you lot need to get a room PMSL |
362bkr Member Since: 06 Dec 2013 Location: devon Posts: 856 ![]() ![]() ![]() |
. Tried it and ................IT WORKS ! ![]() |
