![]() | Home > General > chips and Power upgrade warning |
Bluff and bluster! Most manufactures can't detect well written codes nor power boxes that have been removed. Believe me, they tried that on with first TDV6 after gearbox failure then had to admit with red faces, that there was a wiring loom failure. Easy way of scaring folk, but even knowing the car had been mapped, they couldn't find the software mod in the ecu even after removing it and checking it at Gaydon. 2x TDV6. SE and HSE. Both returned to sender with issues👀
npinks Site Moderator Member Since: 27 Nov 2007 Location: Watching Posts: 6716 ![]() ![]() |
That maybe be true, but they obviously have cause to send it out to dealers warning them
Agree its worth being cautious but they need to prove beyond suspicion to void guarantee as it is a legal agreement. Went through this with son's VXR Corsa when it lunched its engine at 18 months old. Vauxhall's get out was non standard brake pads which had been supplied by their network as upgraded version. Ecu was eventually removed and checked but was standard map from factory as we claimed. After several solicitors letters, a new engine was fitted under warrantee. I am sure it is common practice throughout the networks, to resist as many claims as possible.
Land Rover are missing out here with most modern day manufacturers offering a remap via their own approved tuning companies, All the German manufacturers have their own approved tuning companies. Land Rover need to catch up. |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9132 ![]() ![]() ![]() |
They need to sort out reliability of the basic product before they mess around with factory tuning options! 2012 SDV6 - it's missing a couple of cylinders
362bkr Member Since: 06 Dec 2013 Location: devon Posts: 856 ![]() ![]() ![]() |
You couldn't be more correct if you tried hard |
Yes, sort the reliability issues first, seems that they are using the maps as an excuse to cover up for their reliability problems |
The standard issue map is to make the engines conform to Euro5/6 and "reliability" rather than performance and economy. As most who have had vehicles mapped will tell you, they go better and do more mpg, I think I averaged 2 mpg more with V6 map 2x TDV6. SE and HSE. Both returned to sender with issues👀
flydive Member Since: 17 May 2007 Location: South Posts: 1213 ![]() ![]() ![]() |
As all above.
