Home > General > chips and Power upgrade warning
Saw this on Topix earlier and found that DG on disco4 posted the actual warning released
Worth a read if your thinking about adding one or even posting on here that you have
DG wrote:
FYI
Quote:
A number of major powertrain units received through the Warranty Returns process have been damaged by the
installation of unauthorized power upgrades to the Engine Management systems.
Changes to a vehicle's power characteristics have far-reaching consequences on many systems including the
entire driveline, braking system, emission control devices and in particular the Diesel Particulate Filter (DPF)
circuit.
The Engine Management System performs regular regeneration cycles to purge the DPF of particulate matter
and unauthorized upgrades can seriously affect these regeneration cycles leading to catastrophic failure of the
DPF.
Power upgrades are typically achieved either through the download of unauthorized and potentially illegal
calibration files into the Engine Control Modules, or through add-on hardware. Other power upgrades may also
be available, and in all cases, warranty responsibility on any affected component does not lie with Jaguar Land
Rover.
The resulting power increase is achieved at the expense of:
• Engine and transmission longevity.
• Increased fuel consumption.
• Increased pollutant emissions.
We would also draw your attention to the following statement from the Owner's Handbook:
'The fitting of non-approved parts and accessories, or the carrying out of non-approved alterations or
conversions, may be dangerous and could affect the safety of the vehicle and occupants, and also invalidate
the terms and conditions of the vehicle warranty'.
Where there is evidence that a vehicle has had an unauthorized power upgrade, authorized repairers should
send an email to ************** with known modification details and the VIN number of the
affected vehicle so that a Warranty restriction can be applied and shown in DDW. In the event of related vehicle
faults, customers should be advised to contact the vendor of the vehicle, supplier of the power upgrade or be
advised that they will incur repair costs.
Authorized Repairers must not be in any way be involved in the promotion, marketing, or installation of such
unauthorized power upgrades. Evidence of upgrade is almost impossible to conceal, even when original
equipment is refitted following unit failure. Any major unit failures suspected to be resulting from unauthorized
power upgrades will be thoroughly investigated and warranty payments will be withheld or withdrawn as
appropriate.
Post #413774 Thu Feb 13 2014 12:14am
simple1
Bluff and bluster! Most manufactures can't detect well written codes nor power boxes that have been removed. Believe me, they tried that on with first TDV6 after gearbox failure then had to admit with red faces, that there was a wiring loom failure. Easy way of scaring folk, but even knowing the car had been mapped, they couldn't find the software mod in the ecu even after removing it and checking it at Gaydon. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #413778 Thu Feb 13 2014 12:43am
That maybe be true, but they obviously have cause to send it out to dealers warning them
Say that they thought they was a remap, their the ones in the driving seat regarding repairing it under warranty or not
Anyway better forewarned than not Thumbs Up
Post #413786 Thu Feb 13 2014 7:57am
simple1
Agree its worth being cautious but they need to prove beyond suspicion to void guarantee as it is a legal agreement. Went through this with son's VXR Corsa when it lunched its engine at 18 months old. Vauxhall's get out was non standard brake pads which had been supplied by their network as upgraded version. Ecu was eventually removed and checked but was standard map from factory as we claimed. After several solicitors letters, a new engine was fitted under warrantee. I am sure it is common practice throughout the networks, to resist as many claims as possible.
A chipped or flashed ecu on early cars is software, I believe post 2009, to upgrade a land rover, you need to actually remove and open ecu which would be obvious at inspection let alone on road test. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #413787 Thu Feb 13 2014 8:12am
Land Rover are missing out here with most modern day manufacturers offering a remap via their own approved tuning companies, All the German manufacturers have their own approved tuning companies. Land Rover need to catch up. Whistle We know our vehicles arn't performance cars as such, sports only by name, but as we all know, no two engines are a like coming off the production line and L/R have tuned a map for all. Little tweaks here and there can make one hell of a difference in the way our motors run. Would i risk my warranty? No. Would i have a remap by an authorised L/R dealer ? Too right i would. Thumbs Up
Post #413788 Thu Feb 13 2014 8:40am
They need to sort out reliability of the basic product before they mess around with factory tuning options! 2012 SDV6 - it's missing a couple of cylinders
Post #413793 Thu Feb 13 2014 9:27am
362bkr
United Kingdom 2012 Range Rover Sport SDV6 Autobiography Santorini Black
Post #413805 Thu Feb 13 2014 10:03am
simple1
You couldn't be more correct if you tried hard Whistle Bow down 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #413809 Thu Feb 13 2014 10:39am
Yes, sort the reliability issues first, seems that they are using the maps as an excuse to cover up for their reliability problems Rolling Eyes
As Ady says, a lot of manufacturers offer their own performance enhancements and are fully warranted (BMW ///M Performance map for example). We all know that cars (whatever brand) are pulled back to very mid range tolerances as they have to suit all markets, especially in Europe.
...........but I think that's a long way off for LR I'd say Wink ON THE WAY: BMW F21 M140i
Post #413811 Thu Feb 13 2014 10:45am
simple1
The standard issue map is to make the engines conform to Euro5/6 and "reliability" rather than performance and economy. As most who have had vehicles mapped will tell you, they go better and do more mpg, I think I averaged 2 mpg more with V6 map 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #413813 Thu Feb 13 2014 11:18am
flydive
As all above.
I also call BS on the transmission/drive-line issues. '08 RRS TDV8
Post #413829 Thu Feb 13 2014 1:08pm
