![]() | Home > General > range rover engine |
| gazzc Member Since: 07 Jan 2010 Location: cheshire Posts: 494
they havnt kinked a fuel line when refitting engine have they,i take it you have fitted new fuel filter,when it is running does it rev up properly silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
| simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657
What engine are we talking about? V6, V8. Petrol or diesel? 2x TDV6. SE and HSE. Both returned to sender with issues👀
| JasM Member Since: 02 Nov 2012 Location: Lanarkshire Posts: 1186
The OP has a 2008 2.7 TDV6. 2014 L405 SDV8 RR Autobiography |
Sounds like a coding issue.......and a job done by those that don't know what they were doing |
If it was coding, I would expect the car not to start at all.
Your presuming that everything was fitted as removed from old engine.
I will assume you are refering to a TD5 Disco. These do need the injectors coded, and programmed into the ECU.
| SRE Member Since: 16 Jan 2010 Location: Alicante Prov Spain + Hampshire UK Posts: 2329
I assume that you have fitted a Euro 4 Engine, not a Euro 3. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Basic engines between EU3 + EU4 are the same, but most parts bolted onto it are different.
hi did you get it running if so what was it as i cant get mine to run |
| All times are GMT |
