Home > General > range rover engine
jae1952
United Kingdom 2008 Range Rover Sport TDV6 HSE Santorini Black
range rover engine
I have a 2008 Range Rover Sport 51000 miles and the engine failed shells turned on the crank . Had a new engine fitted but the garage cannot get it to run for more than 4 minuits. The fuel pressure drops in the fuel rail . Has anyone any ideas please at my witts end .
Post #412996 Fri Feb 07 2014 6:01pm
gazzc
2005 Range Rover Sport TDV6 HSE Siberian Silver
they havnt kinked a fuel line when refitting engine have they,i take it you have fitted new fuel filter,when it is running does it rev up properly silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Rimini red rrs 2.7 tdv6 steps. Full c code. Recon engine!!loved but!gone ,thank god !!
Gone rr sport supercharged. Loved but 11mpg !!!
current,triumph stag mk2...current bmw 325 sport convertible
Post #413000 Fri Feb 07 2014 6:27pm
simple1
What engine are we talking about? V6, V8. Petrol or diesel? 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #413034 Fri Feb 07 2014 11:45pm
JasM
Scotland 2012 Range Rover Sport SDV6 HSE Orkney Grey
The OP has a 2008 2.7 TDV6. 2014 L405 SDV8 RR Autobiography Cool
2012 RRS SDV6 HSE -Orkney Grey with A/B bodykit - Now Gone Sad
2007 RRS TDV6 HSE - Zermatt Silver - Gone
Post #413037 Fri Feb 07 2014 11:55pm
simple1
Sounds like a coding issue.......and a job done by those that don't know what they were doing Whistle 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #413042 Sat Feb 08 2014 12:22am
Disco_Mikey
If it was coding, I would expect the car not to start at all.
Any there is nothing that should need coded after replacing an engine. Have done plenty of them, and never even had to do as much as clear fault codes to get them up and running.
It sounds as though it is running out of fuel. Maybe the pickup filter in the tank is blocked, or even a slight leak in the HP side of the fuel system, causing it to loose pressure, and stop running.
A bit more info on how it runs, and how they get it to run again would be nice to help further diagnose Thumbs Up
Post #413046 Sat Feb 08 2014 1:27am
simple1
Your presuming that everything was fitted as removed from old engine.
We had a Disco brought to us that wouldn't run correctly and after much head scratching, and several calls to a grown up, it transpired that injectors had been mixed up and were re-programmed which solved the problem. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #413051 Sat Feb 08 2014 8:48am
Disco_Mikey
I will assume you are refering to a TD5 Disco. These do need the injectors coded, and programmed into the ECU.
However, a TDV6/TDV8 engine does not Thumbs Up
Post #413055 Sat Feb 08 2014 9:15am
SRE
Spain
I assume that you have fitted a Euro 4 Engine, not a Euro 3. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #413066 Sat Feb 08 2014 10:38am
Disco_Mikey
Basic engines between EU3 + EU4 are the same, but most parts bolted onto it are different.
Most important will be the fuel system. The EU3 wiring loom will not reach the necessary parts of the EU4 HPFP + fuel rails, and vice versa, so I think this can be ruled out
Post #413158 Sun Feb 09 2014 9:38am
gazzc
hi did you get it running if so what was it as i cant get mine to run Bow down silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Post #415459 Tue Feb 25 2014 5:02pm
