![]() | Home > Technical > bought tdv6 sport with blown engine |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4509 ![]() ![]() ![]() |
Pistons, rings and con rods. And repair instructions |
Making sure it goes back together correctly. Check out a thread on here by Simple1 about his TDV8 that was rebuilt |
gazzc Member Since: 07 Jan 2010 Location: cheshire Posts: 494 ![]() ![]() |
have you got a link to it please i cant find the thred silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
muddywheels Milk Float Man Member Since: 01 Jul 2010 Location: East Riding of Yorkshire Posts: 5643 ![]() ![]() |
http://www.rrsport.co.uk/forum/topic31666.html?highlight=tdv8 |
Here's a summary one, can't seem to find the original 20 page thread.
http://www.rrsport.co.uk/forum/topic29765.html?highlight=engine |
thanks,has anyone on here rebuilt a tdv6 if so did you harden/nitride the crank,did the engine last,thanks |
What happened to the original engine?
it had been run low on oil and picked up on no 2 on the crank,was still running just had a knocking rod so i have had crank ground and hardened 1 new rod,very expensive mains and big ends ,its just ready to be built now,my mechanic is saying skim the heads but im not sure as they were fine before,not trying to save money as i want it right but just cant see the point of skimming if there flat,am i wrong |
Interested to know where you bought a "new" conrod |
If you're fitting just the one con-rod you might be advised to weigh it (with its big-end cap and bolts) and makes sure it is in balance it with the others.
thanks for replys,sorry meant to say second hand rod,crank is in and all measured up with correct end float etc |
marcspark Member Since: 11 Feb 2014 Location: Cambridgeshire Posts: 4 ![]() ![]() |
Hi Gazzc |
Hi Marc. My engine is built and fitted. I paid 100 for crank grind. 140 for the nitride 72 hour hardening process 40.00 to get the crank re polished 400 for the .5 oversized bearings I'm not sure of the exact clearances etc as i left it up to the guy that ground the crank. He advised me of correct bearings and end float oh and had to buy a second hand rod as mine was shot. I was advised to definately not rebuild without nitriding crank as it would not last. Garry silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
