Home > Technical > bought tdv6 sport with blown engine
gazzc
2005 Range Rover Sport TDV6 HSE Siberian Silver
hi i have recently bought a blown engine tdv6 sport ,engine and gearbox is out now and engine stripped crank reground and toughened as i was advised to,is there anything my trusty mechanic should look out for when rebuilding,thanks silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Rimini red rrs 2.7 tdv6 steps. Full c code. Recon engine!!loved but!gone ,thank god !!
Gone rr sport supercharged. Loved but 11mpg !!!
current,triumph stag mk2...current bmw 325 sport convertible
Post #410513 Tue Jan 21 2014 7:22pm
Disco_Mikey
Pistons, rings and con rods. And repair instructions Whistle
Post #410631 Wed Jan 22 2014 9:46am
Making sure it goes back together correctly. Check out a thread on here by Simple1 about his TDV8 that was rebuilt Wink
NB.......after reading it you may regret your decision Shocked Whistle ON THE WAY: BMW F21 M140i
Post #410632 Wed Jan 22 2014 9:59am
gazzc
have you got a link to it please i cant find the thred silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Post #410697 Wed Jan 22 2014 5:32pm
muddywheels
Milk Float Man
http://www.rrsport.co.uk/forum/topic31666.html?highlight=tdv8 Big Cry Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #410698 Wed Jan 22 2014 5:42pm
Here's a summary one, can't seem to find the original 20 page thread.
Edit: SNAP!!!!......too slow Embarassed ON THE WAY: BMW F21 M140i
Post #410700 Wed Jan 22 2014 5:47pm
muddywheels
Milk Float Man
http://www.rrsport.co.uk/forum/topic29765.html?highlight=engine Whistle
Driving your Beemer is dulling the grey cells Laughing Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #410701 Wed Jan 22 2014 5:55pm
gazzc
thanks,has anyone on here rebuilt a tdv6 if so did you harden/nitride the crank,did the engine last,thanks Thumbs Up silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Post #410705 Wed Jan 22 2014 6:47pm
Disco_Mikey
What happened to the original engine?
Broken con rod, melted pistons, oil pump casing?
I would not trust a "reconditioned" TDV6 purely because you cannot buy parts to recondition it, and there are no repair instructions from JLR ro rebuild it
Have done a few top end rebuilds. Nothing difficult there...
Post #410710 Wed Jan 22 2014 7:30pm
gazzc
it had been run low on oil and picked up on no 2 on the crank,was still running just had a knocking rod so i have had crank ground and hardened 1 new rod,very expensive mains and big ends ,its just ready to be built now,my mechanic is saying skim the heads but im not sure as they were fine before,not trying to save money as i want it right but just cant see the point of skimming if there flat,am i wrong Confused silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Post #410711 Wed Jan 22 2014 7:35pm
Disco_Mikey
Interested to know where you bought a "new" conrod Thumbs Up
Mains and big ends are very expensive, as you have found out Rolling Eyes
As for the heads, I would have them skimmed, and the glow plugs removed/drilled out while the heads are already off the car Thumbs Up
Will save you lots of grief in the future
Post #410752 Thu Jan 23 2014 9:59am
drdelrrs
If you're fitting just the one con-rod you might be advised to weigh it (with its big-end cap and bolts) and makes sure it is in balance it with the others.
If you've reground the crank its also a good idea to assembly the engine's 'bottom end' and check and measure the clearances on all the bearings - main and big-end. Its quite common for the shells to differ and often by swopping them about you can match the crank journals to the bearing shell to get the correct cold clearances.
Spend the time now and you'll end up with a smoother and more reliable engine.
Post #410753 Thu Jan 23 2014 10:10am
gazzc
thanks for replys,sorry meant to say second hand rod,crank is in and all measured up with correct end float etc Thumbs Up silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Post #410756 Thu Jan 23 2014 10:57am
marcspark
Hi Gazzc Very Happy I'm in the process of waiting to repair my engine Censored , Saving pennies Shocked
Do you know what make of bearings were used Ie Fedral Mogel - bearing numbers or identity marks :~))), etc. I've found a few bearings that will fit but not sure if there be Ok for a powerful diesel engine.
When you had the crank reground, do you know what size is was ground to before the harden/nitride was carried out? As it must of been ground probably 20 thou below .5mm .5mm=about 40 thou so the nitride process built up to above finished level before polishing.
I've seen bearings from Brit part for over £600 Censored Censored and there is someone who is selling them on Ebay for just under £400 but i'm not sure if i trust them. Evil or Very Mad
I'd want to know what the internal/external measurements are, so i would be happy that they would fit properly. As it's would be no good having bearings with an outer diameter 10 thou below the 75mm of my main bearings which would lead to hardly any bearing crush.
Also would you know how much the nitride process cost?
Good luck and keep us posted, If you want some rebuild info, i have a citroen C6 Technical information on PDF which covers the engine, I also have a jaguar rebuild manual which covers all the engines including TDV6 in PDF if you need them Thumbs Up
Cheers Marc Very Happy
Post #413577 Tue Feb 11 2014 10:24pm
gazzc
Hi Marc. My engine is built and fitted. I paid 100 for crank grind. 140 for the nitride 72 hour hardening process 40.00 to get the crank re polished 400 for the .5 oversized bearings I'm not sure of the exact clearances etc as i left it up to the guy that ground the crank. He advised me of correct bearings and end float oh and had to buy a second hand rod as mine was shot. I was advised to definately not rebuild without nitriding crank as it would not last. Garry silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Post #413583 Tue Feb 11 2014 10:53pm
