Home > Technical > Procedure for removing front valve blocks
LOCUST
Gonna have a go at cleaning the front valve blocks out.
What's the procedure for removing these ?
Access mode, battery disconnect, jack up and remove ?
I presume by putting in access mode is should have no air in the system when I remove them ?
Cheers.
Post #409959 Fri Jan 17 2014 8:35pm
http://www.rrsport.co.uk/forum/topic29358....lve+remove
Any help? 2012 SDV6 - it's missing a couple of cylinders
Post #409991 Sat Jan 18 2014 12:32am
LOCUST
Yeah cheers that's what I'm following, it just doesn't mention the lead up to removing it.
Post #410015 Sat Jan 18 2014 10:47am
Paddi
To fully deflate the suspension you really need a suitable diagnostic tool. The IID tool will do it and presumably any of the other decent tools like Auto logic. Perhaps just raising and lowering a few times without the engine running would do it too if that's possible? 2008 MY Java Black TDV8 HSE
Post #410029 Sat Jan 18 2014 1:08pm
