![]() | Home > General > Does anyone else get a driveline shunt at low speeds?SORTED! |
factoryfil Member Since: 02 Feb 2012 Location: Norwich Posts: 26 ![]() ![]() ![]() |
I have a similar age and milage rrs, I done a gearbox fluid and filter change recently and it improved the operation of the box alot, stopped the low speed revs fluctuating and lumpy downshift issues, over a 100k on the same oil doesn't seem quite right? the genuine fluid and filter pan are expensive but seemed worth it compared to the cost of a new box,hopes this info helps |
Topvaruk Member Since: 27 Nov 2011 Location: Berkshire Posts: 6 ![]() ![]() |
murdered out
dvb247 Member Since: 11 Apr 2012 Location: Cheshire Posts: 53 ![]() ![]() ![]() |
My RRS is 9 months old, I have noticed this issue too, I was convinced I had a broken seat, I think I'm going to chat with Stockport LR as I'm still not happy with the huge lag when pulling out of a junction or reapplying the accelerator when going round a roundabout!! If you've got it, spend it! |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9148 ![]() ![]() ![]() |
The "lag" when pulling away from rest such as at a junction is caused by the gearbox defaulting to 2nd gear when pulling away. If you select 1st gear as you get to the junction, you should find that it's quicker to go when you ask it to. 2012 SDV6 - it's missing a couple of cylinders
Byreman Member Since: 03 Jun 2013 Location: Redditch Posts: 13 ![]() ![]() ![]() |
I have a 2008 2.7 HSE RRS and its done this for around 3 years. Dealer says it a feature of the car. Annoying but only happens when you slow down quickly and accelerate again. Thunk..... Still it's no worse than 3 years ago..... |
I am sure there is a software upgrade called anti bump for the v8 gearbox that is supposed to fix this issue
theforman Member Since: 02 Mar 2012 Location: wolvo Posts: 16 ![]() ![]() ![]() |
i toooo had the very same problem it was the centre propsahft bearing which had a tare in the rubber bush,, i changed it and wayyyhhhhat the problem went £52 off ebay,, happy dayys ![]() |
Stuart Member Since: 18 Oct 2013 Location: Manchester Posts: 581 ![]() ![]() ![]() |
I wonder if anyone has any conclusive solution to this?
Stuart
Is there a reference number or anything for this patch? In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
samson Member Since: 09 Dec 2014 Location: Warsaw Posts: 8 ![]() ![]() ![]() |
I'm also waiting for any reference number for this soft update... |
Rangie78 Member Since: 28 Dec 2015 Location: Cumbria Posts: 5 ![]() ![]() ![]() |
It looks like it has already been said but just wanted to share that I had the same driveline shunt issue. My local dealer (Lloyds of Carlisle) said it needed a load of suspension bushes changing.
That's great thanks, I will get my garage to try that one...... Why a double gearbox flush ? Any ideas ?? |
Jaggs Member Since: 09 Aug 2015 Location: Leeds Posts: 259 ![]() ![]() ![]() |
Double gearbox change to try and get all the old oil out but it doesn't, your better with a gearbox flush |
