![]() | Home > Technical > EPB Strange Problem |
| TDV8Mat Member Since: 17 Dec 2013 Location: East Yorkshire Posts: 139
Quick update on this, I've fitted a new battery this morning just to rule it out (as it was still on the original one) and it hasn't cured it |
| MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104
IIRC blown brake lamps (or possibly any other lamp) throw up faults like this.... |
| Paddi Member Since: 06 Jul 2012 Location: Hertfordshire Posts: 1563
So when you clear the fault code with the diagnostic tool it just reappears on the next start? 2008 MY Java Black TDV8 HSE
@maw Brake lights all work correctly.
| Beancounter_74 Member Since: 11 Oct 2011 Location: Down here now... Posts: 5796
Are they genuine LR bulbs in the brake and indicator lights, I know that people have posted that the electrics can be VERY fussy when it comes to what type of bulbs are replaced. ON THE WAY: BMW F21 M140i
I don't know whether the bulbs are genuine or not, none have been changed recently though. Just been and checked again that they all work, and they do. |
| mse Member Since: 08 Mar 2011 Location: Warwickshire Posts: 2916
There could be an actual fault with the system (wiring) or sensor...warning lights do sometimes indicate the real problem |
Think I agree. Sounds like a wiring fault. Perhaps try a search for anything similar to see if there is a common place to find the exact location? 2008 MY Java Black TDV8 HSE
Right I Googled the C1A48 code and found a Landrover Service Bulletin, which basically said the fault was either the Parking Brake Switch, the Instrument Cluster or the wiring inbetween.
Having no idea how its wired...surely if you unplug the switch then it will be a permanent fault anyway.
I agree that if the switch is unplugged it may then log a fault, but one of the issues I have is the 'handbrake on' warning light on the dash, even when I lock the car. I'm thinking if the switch was causing that, unplugging it would make the light go off.
Did you find the full text of the TSB? Asking because they usually have full instructions. Googling the TSB number sometimes finds the full text. You'll get there in the end so keep going! 2008 MY Java Black TDV8 HSE
The system will check the switch - if the switch is not there or faulty it will indicate a fault and you get the light, so either way unplugging will not ID the fault. Unplug and test the switch separately would
Update - I've got this fixed! Traced the wiring back to the n/s/r wheelarch where the wiring loom goes over the chassis and found a wire had rubbed through and must have been earthing out. Cut the wire out and soldered in a new piece, erased the fault and it's all sorted. Chuffed to bits!
| All times are GMT |
